GEN 2 A totally different rattle
OPT PRIME
I already had the cam phasers and timing system replaced at 24,000. Now at 28,000 miles I have this when the oil is cold. In gear, blipping the throttle to 1100 rpm. You can hear it the first ten or so minutes of driving, it’s oil temperature dependent. Fe (iron) is up on the latest 4,000 mile oil sample.
TwizzleStix
Commivirginia
Sounds like the timing chain or cam gear is touching the front cover occasionally. The reason may be the cam chain tensioner is loose on one side or the other. Could be there is some left-over parts floating around inside the cam covers as well. Obviously the precursor to another teardown to determine.
DBro
St. Albert, AB, Canada
MY truck has been in the shop multiple times for a similar issue, I have about 37,000KM (23,000Miles). its like the engine is miss firing and lugging/ surging in the first 20 or so minutes of it running. they've changed injectors/plugs, changed o2 sensors, fuel pump, replaced both cats and HEGOS? it worked for a little bit but now its back with vengeance and lugging even worse! Im also pushing for a new engine as my truck has been in the shop more then I have been driving it. if you could let me know if that is similar to the issue you are having and if anything has solved it.
O
OPT PRIME
My truck runs great, just sounds like it has an intake full of marbles.
RMB_Ryan
Wayne, NJ
What oil are you running out of curiosity
atl_raptor
Mine had/has the same issue. New engine from afore. BUT it’s been at dealer 76 days so far waiting for parts.
