6.2 stroker crank
Raptor 2014
This is the cheapest option - If the rods are a standard over the counter, It would be a great way to go.
Only a .125" offset grind for 402 CU.IN dependent upon bearing.
Oil squirters might hit the pistons and can be deleted but an oil squirter will keep any piston cooler.
.030" over bore is safe - Thin cylinder walls.
