GEN 1 6.2 maximum boost
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by dxbraptor, Nov 26, 2017.
Sponsored By: GotExhaust
  1. whoisbigman
    whoisbigman Full Access Member
    52
    527
    428
    Dec 11, 2013
    Palm Beach Florida
    11, 12, 13 psi... these conversations always get me because I come from the diesel world prior to my Raptor. Truck in sig would hit 40 psi just hitting it on the street. 7.3 after this one would hit 50 psi under load. Some Cummins guys see 60+ on street trucks and with pulling trucks, the sky is the limit...
  2. ROCKETW19
    ROCKETW19 Full Access Member
    306
    75
    Aug 9, 2015
    those are not super charged gas motors they are turbo diesels built way different.
  3. whoisbigman
    52
    527
    428
    Dec 11, 2013
    Palm Beach Florida
    I knew something was different... Is that why i had to use the "special" green handle gas from the gas station?
  4. ROCKETW19
    306
    75
    Aug 9, 2015
    lol yup
  5. Airborne Roush
    Airborne Roush Member
    37
    5
    Nov 15, 2017
    Utah
    Are you going to use a voltage boost to help the pump run more consistently?
    Something like this?
    https://www.lethalperformance.com/j...n-by-maf-map-tps-or-ground-plug-and-play.html
    Also 3 gal/min is insane!
    Are you going to throw meth on to help with the octane?
    900 rwhp is something like 1,110 at the crank! I hope you post what you are working on... I'm sure we would all like to see
  6. Sigmoid
    Sigmoid Full Access Member
    55
    49
    Apr 11, 2014
    I'm going with dual 450's AND a voltage booster....That should get me enough fuel. Looks like I'm going to just fab some rails out of my existing ones. May have to upgrade from my 95lb injectors...but we'll see. I'll have multiple tunes, some for normal gas and some for E85 (which means I need like 30% more fuel). I'm going into it with the idea of making it capable of 1,200 hp at the crank.
    I'm not sure, but I think it will be one of a kind.
  7. Biggest
    Biggest FRF Supporting Member Supporting Member
    877
    1,113
    Jul 2, 2013
    Have. I’m still alive!
    Truckzor likes this.
  8. SD_Plat
    SD_Plat Member
    43
    7
    Feb 3, 2014
    How’s the truck?
  9. Biggest
    877
    1,113
    Jul 2, 2013
    A little more insane
    ---------- Post added at 07:01 AM ---------- Previous post was at 06:59 AM ----------
  10. SD_Plat
    SD_Plat Member
    43
    7
    Feb 3, 2014
    Well thats a tease... how about an update :) I followed your build closely and would love to hear how everything is holding up.
Share This Page
