Triple Fog Light Kits Featuring 100% American Made/Stainless Steel Brackets
4x4TruckLEDs.com
SPECIAL SAVINGS
Use coupon code FOGS at checkout and we'll take some $$ off your fog light kit purchase.
Outfit your truck with some of the best LED Fog Lights money can buy. Our Triple Fog Light Kits offer you the most adjustments out of any kit on the market, while allowing you to choose exactly which lights to go with. We all live in different parts of the country/world and as such have different needs for our lighting. What works for the local Starbucks run in Wyoming might not work for the off-road enthusiast going to Baja. We got you covered though!
The KR Off-Road Triple Fog Light Brackets have the most adjustments of any bracket currently on the market.
-Made in the United States (right here on Long Island)
-11 Gauge Stainless Steel
-Powder Coated to add another level of protection
-Vertical Mounting points allow you to center the entire assembly in your bumper opening
-Horizontal Mounting points allow you to slide your lights left/right
-3 different horizontal channels to choose from allowing you to mount your lights as forward/backward in the opening as you need
-Align each light individually up/down/left/right allowing you to focus your light precisely where you need it
-The only fog kit on the market that offers our "Raptor Lifetime Guarantee". If you damage the KR Off-Road bracket in anyway during the course of "Raptoring" we'll replace the bracket(s) free of charge (that means if you take it off a sweet jump and land on a rock crushing the stainless steel, we'll replace the bracket for you).
Not only that, but we're the only ones currently offering extension brackets for your Baja Designs lights. Typically you would mount your lights upside down (hanging from the bracket). The downside to this is that your Baja Designs logo will be upside down and, more importantly, your lenses might be upside down. We're currently the only ones who have custom designed in-house an extension bracket that attaches to the Baja Designs lights that lets you hang them right-side up. That means a quicker and easier installation (as you do not have to remove any bezels on the Baja Designs lights).
These extension brackets are also made right here on Long Island out of stainless steel and powder coated black as well (ensuring everything matches and a lifetime of use).
Baja Designs Sportsmen Kit: https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights-sportsmen/
  • S2 Sport, Wide Cornering (Pair)
  • Squadron Sport, Driving/Combo (Pair)
  • Squadron Sport, Spot (Pair)
Baja Designs Pro Kit: https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights-pro/
  • Squadron Pro, Driving/Combo (Pair)
  • Squadron Pro, Spot (Pair)
Baja Designs Unlimited Kit: https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-baja-designs-lights-unlimited/
  • S2 Pro, Wide Cornering (Pair)
  • Squadron Racers, Spot (Pair)
And of course you can Build Your Own Kit: https://www.4x4truckleds.com/2017-f...ght-kit-w-baja-designs-lights-build-your-kit/
Rigid Industries D-Series Kit: https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-d-series/
Rigid Industries Radiance Kit: https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-radiance/
Baja Designs Kit: https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-diode-dynamics-stage-series-3/
Rigid Industries 360 Series Kit: https://www.4x4truckleds.com/2017-ford-raptor-triple-fog-light-kit-w-rigid-industries-360-series/
FastEddie
Looks interesting!
Some questions
I have 2 sets of squadrons on hand already. Can you sell with the bracket and an S2 or bracket only?
I would like to use one of the lights turned out as a cornering light. Is that possible? If so, which light can you turn out?
How does this bolt up?
Any pics of this mounted?
4x4TruckLEDs.com
4x4TruckLEDs.com
Yes we do sell the brackets only. They are $149 (about $20 cheaper then Rigids).
We stock most of the Baja Designs products so yes you could buy the brackets and a set of S2 lights. We offer all of the Baja Designs lights in any lens pattern (we stock every lens they make). So yup, you can order up the S2 lights with wide cornering (either white or amber).
It installs almost the same way as every other kit (almost all of the kits utilize the same factory mounting locations for the most part)
Brackets Only: http://www.4x4truckleds.com/2017-ford-raptor-fog-light-brackets/
Brackets w/Lights: http://www.4x4truckleds.com/2017-ford-raptor-fog-light-kit-w-baja-designs-s2-squadron-lights/
S2 Lights: http://www.4x4truckleds.com/led-driving-fog-lights/baja-designs/
FastEddie
Cool.
You have any pics showing this installed?
Also how "aimable" are the various lights?
4x4TruckLEDs.com
4x4TruckLEDs.com
We'll have some photos soon Eddie. They are adjustable up/down/left/right. I mean yeah you can't adjust them 360 degrees because you still have the bumper that will stop them eventually but you can make some slight adjustments if you need to and move them forward/back to suit your taste (they sit in a channel on the bracket so you can slide them forward/back if you need to make adjustments or run bigger lights like 3 pairs of Squadrons, although we recommend 2 pairs of squadrons and 1 pair of s2 which is why we have them setup that way, the last light would get blocked a bit, so the smaller light works best)
FastEddie
Ok. Looking forward to pics.
What about the wiring harness. How much for that?
4x4TruckLEDs.com
4x4TruckLEDs.com
All necessary wiring harnesses are included with the purchase of our Fog Kit. IF you just want to buy the brackets separate you'd need to buy the wiring adapters separate.
Baja Designs Pairs include the necessary Y-Cable to connect the two to one circuit. Those are included in all Baja Designs pairs when you buy them. You then just need to get the upfitter harness if you want to connect it to your upfitters (which are only like $13).
FastEddie
I have 2 pair of Squadrons I pulled off my 2014. I’d like to use them, potentially with this bracket and your wiring harness. I left the old harness on the old Raptor. How much for a harness.
4x4TruckLEDs.com
4x4TruckLEDs.com
FastEddie
Cool. So if I want the 3 pairs of lights to be switched independently, do I need 3 upfitter harnesses and 3 splitter harnesses?
