3rd Brake Light Gen 2/3
Jhollowell
Everett, wa
I designed and machined my own 3rd brake light. These will fit 2017+ Raptors and are plug and play. You will lose the cargo camera if you install it on a Gen 3 though. Will come with LED brake/running lights, gaskets, new hardware, and wire harness. Everything is brand new. NMO version is available and will come with the NMO cable and a hole in the top of the light to mount it. There is also a version that uses 3w LED's for the cargo light if you don't want to use a BD light for cargo. Prices below include shipping. Feel free to contact me for more pictures or questions.
Gen 2.1 - Baja Designs cargo - $450.00 NMO - $475.00
Gen 2.2 - 3w LED cargo - $450.00 NMO - $475.00
Gen 3.1 - Baja Designs cargo - $450.00 NMO - $475.00
Gen 3.2 - 3w LED cargo - $450.00 NMO - $475.00
Jhollowell
Jhollowell
Everett, wa
Yes it does. They are at half intensity when the running lights are on and full brightness when you hit the brakes
Jhollowell
Jhollowell
Everett, wa
Here is some additional info.
PNW 2.1 Gen 2 Raptor Overview
This billet aluminum brake light fits 2017-2020 Ford Raptors and allows for the installation of 3 Baja Designs S2 lights.This kit comes with new mounting hardware, gaskets, prewired LED brake lights and a wire harness to connect your S2 lights to the factory up-lifter switches.Additional gaskets and wire harness available.
- CNC Machined from billet 6061 aluminum.
- Designed and manufactured by small business in the USA.
- Uses existing bolt holes.No drilling required.
- Plug and play integration with the factory wiring for brake, running and cargo lights.
- Wire harness included.
- Three 1w Red LED brake lights.
- NMO Mount available.
- Flat black powder coat finish.
- Baja Designs lights NOT included
Installation:
Remove the OEM light and unplug the connector from the back of the light.
Plug in the new harness to the OEM connector.
Connect the weather pack connector with the red connector to the center S2 light. (cargo)
Connect other 2 weather pack connectors to the outside S2 lights.
Run the S2 harness along the headliner, down the cab to the passenger fuse box area and connect the colored wires to your up-lifter switch wires.
Install light with new screws.
Connect the black wire to chassis ground.
· Its recommended to add a bead of RTV silicone around the top and sides to provide additional water protection.
Jhollowell
Jhollowell
Everett, wa
PNW 2.2 Gen 2 Raptor Overview
This kit is similar to PNW 2.1 but uses prewired cargo lights instead of a Baja Designs light.Fits 2017-2020 Ford Raptors and allows for the installation of 2 Baja Designs S2 lights.This kit comes with new mounting hardware, gaskets, prewired LED brake lights and cargo light and a wire harness to connect your S2 lights to the factory up-lifter switches.Additional gaskets and wire harness available.
- Two 3w White LED cargo light
Installation:
Remove the OEM light and unplug the connector from back of light.
Connect weather pack connectors to S2 lights
Jhollowell
Jhollowell
Everett, wa
They are powder coated so that’s going to be one of the most durable finishes you can get. If you’re really concerned with UV protection you could mask off the brake LEDs and spray it with a clear UV coating if you want.
Zeusmotorworks
LOTS of different types of powder coat... some oxidize next to immediately, others last forever. It's a legit question. You work look s great, but it's quality that is going to get your through all the red tape.
