39-40in tires
Discussion in 'Ford Raptor Wheels & Tires Forum [GEN 1]' started by timbo33, Jan 4, 2018.
Sponsored By: Texas Motorworx
  1. timbo33
    timbo33 Member
    29
    Jul 2, 2015
    I have a 2013 raptor with fox 3.0s front/back.
    I’m running 37in BFG tires right now, no fiberglass and they work fine.
    I purchased the +4 2in fiberglass and want to get bigger tires. Don’t plan on getting any long travel system right now. I want to run a 39 or 40in tire. I’ve looked up answers but can’t seem to find anybody actually doing it. What do I need to do to make it work. Mainly because I like the look, but also want it to function off road as it does now.
    Please let me know how to go about this
  2. Aaron
    Aaron Meme Corps Commandant
    35
    13,164
    7,457
    Jun 13, 2011
    Tucson,AZ
    39's can be done. Walter Burch and Donnie Steele on Facebook have done it. I'd assume to run hard you're going to need to do some firewall trimming which isn't going to be the most fun.
    Edit to add. Your Power steering will not thank you for doing this mod.
    John813 likes this.
  3. timbo33
    timbo33 Member
    29
    Jul 2, 2015
    Ok! Do you know if they are running the stock suspension setup? Or more advanced long travel?
    As of now I wouldnt be doing any upgrades suspension wise, but would like to use the bigger tires.
  4. Aaron
    35
    13,164
    7,457
    Jun 13, 2011
    Tucson,AZ
    Walters was on 3.0s AFAIK, Steele is on some other advanced shit.
    If you really are intent on trying this, Look for some used ones you can mount and try out. It'll be REAL apparent where trimming and rubbing is taking place.
    Also, like I said, your steering rack is NOT going to like you.
    Truckzor likes this.
  5. timbo33
    timbo33 Member
    29
    Jul 2, 2015
    Ok thanks!
    I have the Howe power steering system from RPG. But the steering rack is stock, but that makes sense now that you mentioned it
  6. Doc Constantine
    Doc Constantine Full Access Member
    359
    158
    Sep 26, 2010
    SoCal
    I think Walter has the Icon setup and Donnie has SVC, probably podium package.
    Steele16 and Aaron like this.
  7. SVT_Aaron
    SVT_Aaron Full Access Member
    438
    259
    Feb 9, 2015
    El Paso/Ft Bliss, Texas
    I am currently running 37" BFG Baja T/A and had to trim/ bend pinch welds on the firewall. which will soon turn into cutting into and push back the firewall and fabricate then weld a plate onto it after. with that being said if you are trying to go 39/40 then you will have to modify for sure. I am running KING 3.0, SVC UCA's, & tie rods, when off-roading and turning sharp the tire is rubbing pretty gnarly against the firewall. the only other time that it rubs is when in reverse and turning sharp. I do know that Donnie Steele is running somewhat the same setup, but his setup is more advanced and running 39"
  8. Steele16
    Steele16 Full Access Member
    786
    474
    Jan 5, 2012
    Centralia, WA
    Mines Podium and I roll the lower all the way ahead with the adjustments before i welded it up. Firewall will need to be moved for clearance at compression though.
    Aaron likes this.
  9. tplee
    tplee Full Access Member
    155
    45
    Sep 28, 2014
    South Carolina
    What wheel backspacing are you running? Will make a world of difference.
    Sent from my Pixel using Tapatalk
  10. SVT_Aaron
    438
    259
    Feb 9, 2015
    sorry for late response, backspacing is 4.75
Share This Page
