Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
His point is despite it saying 35" or whatever on the side of the tire, it's usually not a full 35". So essentially equivalent sizes. I doubt you'll notice anything between 315s and 35s.
It has been discussed. The reason is that the stock tires are load range C. They are more pliable for off road rock crawling and smoother riding on the street. The tire was developed for the Raptor. Going to a higher load range will slightly effect the ride and not accomplish anything.
35’s fit the truck fine even in the stock configuration. The problem arises when trying to go up to 37’s so if you want to switch from the stock 315/70/17 to a true 35/12.5/17 your good.
