3" Kings for Raptors
King Shocks
Garden Grove, CA
King Shocks Ford Raptor 3.0 OEM Performance Kits Available
King Shock's new bolt-on, OEM performance kit for the Ford, Raptor delivers increased wheel travel, damping force and overall performance when compared to the stock suspension. King's engineers have spent countless hours tuning the shock valving to enhance off-road performance without compromising the Raptor's on-road manners.
The front monotube, 3-inch diameter coil over with King's Wide Range Compression Adjuster has over twice the piston surface area to provide greater damping control and 20 precise clicks of compression adjustment to fine tune the ride for any type of terrain. The nitrogen charged remote reservoirs help to cool the shock fluid and prevent shock fading when you need performance the most.
In the rear, the kit comes with a race proven 3-inch diameter, triple bypass shock with nitrogen charged, "Piggyback" remote reservoir. The bypass tubes adjust both compression and rebound damping to provide total control throughout the travel range.
Like all King shocks, they are made in the USA to strict precision tolerances using the finest billet materials available and are serviceable with simple hand tools. When the time comes, you can rebuild your King shocks to factory fresh condition for many more years of reliable service. If you want uncompromising performance from your Raptor, nothing else provides the durability or control that King does. When you ride on Kings you'll know, there really is a difference.
K
King Shocks
Garden Grove, CA
This kit is available through Outlaw Raptor, and ADD. Please support these vendors as they support this website.
SoSmoked
changes his exhaust setup more than his underwear
I'd upgrade, however only when I break the fox shoc first... Hmm lemme go work on that one
How much for the kit
Raptizzle
FYT
Southern CA
Where the hell were these guys when SVT contracted Fox?? Could've used these things right out of the gate!
