- Joined
- Jan 29, 2012
- Posts
- 1,097
- Reaction score
- 591
Fits 2024 Ford Raptor Gen 3 Refresh. This is still the Gen 3, but it is the refresh model with recent updates.
Why do I need a metal guard?
The factory Ford Raptor Gen 3 (refresh) has a large plastric openings that don't protect your lower active ******** and coolers. We designed a metal guard that is powder coated black and has a rugged design. It replaces the factory plastic trim in your lower bumper to add some protection and even light up the night. You can add two (2) LED light pods to make your Ford Raptor Gen 3 (refresh) truly one of a kind.- Protects Your Ford Raptor– Protects from rocks and road debris
- Prevents Damage to the Truck – Shields the lower bumper center opening
- Very simple install - no cutting or drilling. Reuse factory bolts and openings. You don't need to take off the whole grille, only unclip back the sides.
DUAL COLOR LIGHT PODS
- Main white LED light is powerful and very bright. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
- The amber or red DRL is purely for aesthetics. It doesn’t give out much light, but more of a backglow. Something extra to make you stand out on the road.
- You choose your backlight (amber or red)
- 1) Amber back light that can be wired as turn signals
- 2) Red backlight that can be wired as turn signals or break light
- Driving/Flood Pattern: longer and wider beam focuses for illumination further down the trail or road as well as peripheral angles
- Each LED light pod is attached to a metal powdercoated bracket
- The only position of these pods is in the center as pictured
- Metal guard is powder coated black
- No cutting or drilling required. The kit is a complete bolt on
