- Joined
- Jan 29, 2012
- Posts
- 1,252
- Reaction score
- 632
Hey Guys, check out our bad ass 40'' Light Bar Pro Kit!
Fits 2024 2025 2026 Ford F150 Raptor
Check out the attached photos from one of our recent clients.
Make Your Summer Nights BRIGHTER with our 40'' Light Bar Pro Kit!! - M&R 2024+ F150 Raptor Gen3 Refresh Standard Bumper 40'' Light Bar Kits
- Fits only standard factory bumper (Non-modular)
- No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware.
- Doesn't interfere with radiator air flow
- Must remove grille
DUAL COLOR: White with Amber DRL
Main White LED Light with Amber DRL (daytime running lights)- White LED -- Super bright and crisp white beam pattern. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the oncoming traffic and also violate road safety.
- Amber DRL -- amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads; it doesn't blind oncoming traffic.
DUAL COLOR: Yellow with Amber DRL
Main Yellow LED Light with Amber DRL (daytime running lights)- Yellow LED -- used in poor driving conditions such as dust, fog, snow and rain. It reflects through air particles much less than the white light, making it ideal for poor driving conditions. For off road use only.
- Combo Pattern: combined spot and driving optics offer a balance between distance and width
- Uses a TIR (Total Internal Reflection) lens, which is different from our regular slim light bar. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
- Higher light efficiency: brighter, longer irradiation distance
- Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to protect against UV, salt water, corrosion, fading and scratch resistant.
- Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
