- Joined
- Jan 29, 2012
- Posts
- 1,078
- Reaction score
- 579
- Fits 2024 Ford Raptor Gen 3 Refresh. This is still the Gen 3, but it is the refresh model with recent updates. If you have previous years 2021-2023, please see other listing.
- The LED pods are dual function light color. It has main white LED light with amber DRL “daytime running lights” backglow. They are purely for aesthetics. It doesn’t give out much light, but more of a beautiful amber backglow. Something extra to make you stand out on the road.
- Upon install, you have full adjustability where you want your pods to shine (straight or to the side to serve as ditch lights)
- Spot pattern
- Low profile
- Easy install
- Doesn't interfere with windshield wipers
- Metal bracket is powder coated black
- No cutting or drilling required. The kit is a complete bolt on using factory hardware
LIGHT POD SPECS:
- Each light pod is
- theoretical max power 40watts
- actual power 39.2watts
- main White light is 3.3amps at 12v
- backlight Amber is 0.07amps at 12v
- theoretical max luminous flux 4,368 lm
- calculated luminous flux (without lens) 4,368 lm
- measured luminous flux (with lens) 2,949 lm
- LEDs type: luminus SST-20 Ra70
- temperature: 6000k
- LEDs number: 4pcs
- **PLEASE NOTE** If you are purchasing just mounting brackets and have different size pods to use, M&R doesn't guarantee correct fitment. It should, but not promised to fit other 3.2in light pods. We can't guarantee 100% fitment and will not accept a return on just brackets. Please do your own research and measurements before.
Our light kits are for off-road use only.
