2024 Aux Upfitter Wire / Fuse issue..
Jepper84
Florida
Hey there, just curious if anyone has run into issues on Gen 3 (2024) Raptor upfitter random switches not getting power.
Yes red taped, yes truck is on, yes other wires are getting power but I'm running into an issue where Aux 2 / Aux 3 aren't getting any power via voltmeter, Aux 4 / Aux 5 are getting power. Just curious how the hell you fix that issue or if its a warranty thing?
Update * Checked fuses, both Aux 1 and Aux 2 fuses have power when I pulled the fuse and checked with a Vmeter. So my guess is somewhere from the fuse to the end of the wire there's an issue? (I do have multiple wires with no power)
AmericanCobra
Seal Beach, CA
YES, but mine was blown fuse.
I just completed adding a new 3rd brake light with Baja Design S2s to Aux 6 on a 3 week old truck. I added Weatherpak connections to all the Aux leads and after attempting to power on via the kickpanel and NO power. Initially thought I hadn't crimped the WP's well enough and decided to tear it all out before I thought to test the fuse. Shame on me... Test found the Aux 6 (5amp fuse) was blown. and of course, it's a fuse type that I don't have...
@Jepper84 did you find an answer? did you try checking continuity between the fuse and end of the hot lead...?
4x4TruckLEDs.com
if you have fog lights Upfitter 1 and 3 will be REVERSED btw. So if upfitter 1's fuse looks good but upfitter 3 is not working for you WELLLLLL it's reversed...
AND if you have a 2024 truck the fuse locations are different from a 2021-2023
here is the 2024 diagram
173 is Upfitter 1 (Upfitter 3 if you have fogs) - 15 Amps
174 is Upfitter 2 - 15 Amps
175 is Upfitter 3 (Upfitter 1 if you have fogs) - 10 Amps
176 is Upfitter 4 - 10 Amps
177 is Upfitter 5 - 5 Amps
178 is Upfitter 6 - 5 Amps
rgz
Broomfield, CO
I do have an intermittent power issue with my aux 1. It sometimes works and sometimes doesn't. Can't seem to figure out why, made sure that my fuses weren't blown and were fully seated but still have this issue from time to time. Haven't bothered to try to diagnose it as I plan to put a switchpro in the truck but it is very annoying.
