2024 801A - False Intrusion Alarms
LochRaven
Auburn Hills, MI
Can anyone suggest how to debug false intrusion alarms? I’ve had my truck for almost two months and have experienced about eight false intrusion alarms. It’s 15 degrees Fahrenheit out, so there are no bugs in my truck that would cause the false alarms, as others have suggested in previous posts. I dropped it off at the dealer today, and they plugged their laptop into my truck and indicated that there were no vehicle faults that would’ve caused the false alarms. So I asked what sensors caused the alarms to be triggered, and they said they have no way of knowing. I found that hard to believe.
Antho
The intrusion sensors are up by the upfitter switches. Pretty sure you can turn them off in the alarm settings.
L
LochRaven
Auburn Hills, MI
Thanks, Antho.
I'm going to assume those sensors are circled in the attached pic. Instead of disabling them and waiting to see if that was the cause, I'd like to keep them enabled and try to use FORScan to see what sensor triggered the alarms.
Thanks.
Antho
yeah. There is one in the center as well. At the bottom of your picture.
L
LochRaven
Auburn Hills, MI
I believe this has been resolved after replacing the key fob battery. The nuisance false alarms increased in frequency to multiple times a day. I replaced the battery, and it did it once, which initially led me to believe that replacing the battery had no effect. But after each passing day with no alarms, I'm convinced replacing the battery fixed my nuisance false alarms issue. Fingers crossed.
L
LochRaven
Auburn Hills, MI
DOH! I Went from multiple false alarms every day to not one alarm in sixteen days after changing the key fob battery. The alarms came back last night, and it did it twice in three hours. The first one was for an "Intrusion", and the second one was for "Unusual Activity". The vehicle was moved between the two occurrences. Thinking that it has something to do with the key fob, I pulled the battery on the one I've always used, and now I'm using the other one that was provided when I purchased the truck. If the false alarms go away this time, it will point to the key fob. Makes no sense to me why the vehicle can't determine the cause and report an error. And I don't understand Ford's use of vague terms for the alarms. Why not say "Intrusion Alarm: Overhead Console Driver-Side Sensor". Or, "Intrusion Alarm: Hood Latch Sensor".
