2024 / 2025 Raptor R - Engine heat
Arizona - Phoenix
Can anyone give some insights as to the supercharger in a hot climate. I live in Phoenix and considering getting the 2025 Raptor R. My 2018 Gen 2 has been flawless in the extreme heat of AZ. I do a lot of city driving with extended idle sits. My day literally starts with turning the engine on at 7am and not shutting it down until 3pm. Any help on this would be greatly appreciated and guide me either back into a Gen 3 Eco or the R.
RaptorMX
Mérida, México
Hello,
Where i live in mexico it is daily between 105 and 115f during the summer with 85% humidity. I have zero issues with the heat of my 2024 Raptor R. Yes he generates crazy heat, but water, oil and trans temperature is always in a good range. I dont have a front license plate, for the airflow to the cooler. Dont know if it makes too much difference.
When i push the raptor super hard, what i do often, it never overheats or reaches critical levels.
You will be fine
Hard R
California
When I take my R out for 6-10hr "spirited runs" through the socal deserts in the summer, I do not notice any significant changes in power or temps throughout the day. I'm sure if you dyno it, the numbers will prove otherwise, but as a driver not really.
Raptorlicious69
Arizona - Phoenix
Thank you. I was talking with Ford performance and their opinion is it shouldn't be a problem. They actually said it'll be better than how most use their R's doing short trips and shutting down the engine. Because the oil is a full synthetic it is better for the engine to run longer than have multiple short trips. When the later happens the synthetic oil isn't heated properly and can form a glaze or build up inside the motor. Ford Performance likes the idea of the engines running longer which prevents this from happening.
Torchy
Nevada
Does no one think these high oil temps in our motors is a problem?
Going up a 1-2 mile hill, I’m seeing 239+ degree oil temps. Based on other threads here, others see similar oil temps.
The gt500’s run 40-50 degrees cooler, at least mine does along with 3 others i know of in the same city.
Anyone make a auxiliary oil cooler?
