2022 Gear Shift Replacement
longhorns
Houston TX
Hey everyone, so i have tried searching other threads but can’t find one specific to my year raptor only 24 and newer.
I have a 2022 Raptor that I bought used and is out of warranty so Im avoiding the dealer. I have been intermittently getting the powertrain/4x4 warnings and gear wrench and my console shifter will no longer fold flat so after reading other discussions my conclusion is i need to replace the shifter.
The replacement seems easy enough and im handy enough to do it myself but what I can’t find an answer to is will the shifter need to be reprogrammed on a 2022 or is it a simple swap? I know the 2024 and up require programming but I don't know about anything older any help is appreciated.
CrazyJeeper
Army
OC, CA & CDA, ID
Just completed mine and can confirm its just a swap
Swapping it in isn't that bad of a project. Did it to my '24.
Can’t confirm but most of the discussions I find that mention programming are 24 and up
Correct. When I did the gear shift module (GSM) on my '24, it needed to be programmed by the dealership, this was before there was a an open customer satisfaction campaign.
When I replaced the GSM, the truck's cluster lit up with every single powertrain light available. At first, I wasn't able to get it out of park with the new GSM because the truck didn't recognize it. I don't know what I did but I managed to get the truck out of park and I immediately drove to the dealership. They reprogramed it under warranty, but that was me playing dumb saying, "I don't know what happened." ¯\_(ツ)_/¯, lol.
  • MC-11029553-0001.pdf
  • Ford Gear Shift Module Customer Satisfaction.pdf
James O
Lubbock Texas 79407
I was looking at a rotary shifter swap for my 2024 truck. Does this mean it will need programing and not just a simple swap? These damn newer vehicles irritate me with everything having a module.
Digipax
NV
I think the 24’s have a encrypted CAN bus and that makes a swap difficult.
See this thread for help….https://www.f150gen14.com/forum/threads/folding-shifter-delete-rotary-knob-swap.35769/
I did my 23 awhile ago with no problems Paddles work just like the folding shifter see photos, I wish you well on your search.
i35it
Army
Dirty East, TX
Would love to know more about your comms setup.
Nathaniel129
California
Where did you get the shifter kit and plate from?
Shifter was from eBay, make sure you get the part number for the Expedition.
The plate was from Etsy, quite a few different variations on there.
I also saw some combo kits of both on eBay.
FYI you'll probably have to message the sellers on eBay; most will want your VIN to verify fitment, and of course a Raptor VIN will make them think the part won't fit. It was a whole thing for me. Had two sellers cancel my order because the VIN wasn't compatible, even after I told them what I was doing.
srfsean
North Carolina
If anyone is wondering the dial shifters from Bronco's without the +/- buttons work as long as it has the "M" button to get into manual shifting mode. Loving the swap on my truck for the last few months.
cscape
Earth
Can you post a picture of your setup?
101,390
60,448
Forgotten Image
