2022 Bed Extender?
doverrover
VA
Who installed a bed extender for their 2022? There are no threads for the center pin to screw into. I've ordered the extender from ford and having a local dealer install it (only $20) so I'm curious on how they are going to attach the center pin...
RaptorTX
TX
I had a Ford OEM bed extender on my 2019 F250 and the center bolts just screw in and thread it as they go. I’m sure it’s probably the same for your application.
doverrover
VA
Negative. The center hole on '22 is now hollow. You can literally stick your finger in there and touch the tail light wires....
MrLiou168
Alta Loma, CA
Same question here... let us know how this works out. I started a thread a few weeks ago and some members said there is no hole there at all.
bzogster
USA
This is a one time removal of the tail lights I assume? Surely it’s not every time you want to put in the bed extender…
DocMarshall
WV
The swing out bed storage from Undercover requires you to remove a taillight as well.
NASSTY
ME
I don't remove mine. 95% of the time it gets used as a bed divider.
doverrover
VA
If you need to take out the extender completely then yes, you need to remove the center pin which looks like it will require to remove the tail light in order to remove the nut that holds the center pin.
