2021 Raptor - Passenger outside mirror not working!!!
Houston
I just took delivery of my 2021 Raptor about 10 days ago. I needed to adjust the side mirror yesterday and nothing happens. The button on my door panel is illuminated but nothing happens when I try to adjust it. The driver's side works perfectly. Is there a simple fix to this? I couldn't imagine it being on its own fuse. I wanted to check before I waste half a day going back to the dealer. Thanks!!!
GTTXRAP
Drill Baby Drill
U.S.A.
Three exclamation points...hate to see how many for a serious issue.
BUT, since it seems urgent, did you press the right mirror button in order to make changes. Just checking.
CACRaptor
Katy, TX
I'm sure it is something simple. It could be that the wiring harness just isn't plugged all the way in?
CoronaRaptor
CANADA
Yep tried that and won’t move when I hit the memory button. Guess I’ll have to make a trip to the dealer.
Hopefully its jUSt a loose wire, better to have the dealer have it than taking the door panel off yourself on a new vehicle. Keep us in the loop, if it's a bad mirror or wiring issue.
