2020 Ford F-150 Raptor – Front camera issue
norway raptor
norway
I’m looking for some help diagnosing a camera issue on my 2020 Ford F-150 Raptor with 60,000 km (approximately 37,000 miles).
The front grille camera (IMPB) initially started flickering and eventually turned completely blue. Around the same time, both Adaptive Cruise Control and standard Cruise Control stopped working.
I also have a fault code stored in the windscreen camera module (IMPA):
C1001-54-AF – Camera calibration required.
I’ve tried calibrating the windscreen camera using Ford IDS. The calibration procedure reports as completed successfully, but the fault code remains, and the systems are still not working.
I’m wondering if the windscreen camera calibration issue could be related to the faulty front grille camera, since the IMPB camera is still showing a completely blue image.
What I’ve tried so far
• Replaced the front grille camera (IMPB), but the image is still completely blue.
• Checked the wiring between the connector near the hood release and the front camera using a multimeter. The wiring appears to be OK.
• Attempted the 360-degree camera calibration using Ford IDS, but IDS aborts the procedure.
• Tried both LIN module initialization procedures, but IDS aborts both of them as well.
• Tried calibrating the windscreen camera (IMPA). IDS reports that the calibration is complete, but the fault code remains.
Camera part numbers
I’ve attached a photo showing both cameras. The original camera is on the left, and the replacement camera is on the right.
• Original camera: Ford P/N LJ3T-19H222-AB
• Replacement camera: Ford P/N LJ3T-19H222-AA
The replacement camera also displays a completely blue image, and the same fault codes remain.
Could the difference in part numbers be the reason the replacement camera is not working or cannot be initialized using Ford IDS? Is LJ3T-19H222-AA a compatible replacement for LJ3T-19H222-AB on a 2020 F-150 Raptor?
Fault codes stored in the IMPB module
• B148E-08-48 – Front Camera: Bus Signal/Message Failure.
• B148E-55-48 – Front Camera: Not Configured.
Both codes are reported as continuous memory DTCs.
The windscreen camera module (IMPA) has the following fault code:
• C1001-54-AF – Camera calibration required.
My questions
Can a faulty front grille camera (IMPB) prevent the windscreen camera (IMPA) from calibrating correctly and cause both Adaptive Cruise Control and standard Cruise Control to stop working?
Could the problem be caused by a LIN communication issue, power supply, ground, wiring, or a faulty module, even though the wiring has been checked and the camera has been replaced?
Could the replacement camera require specific configuration or initialization using Ford IDS?
What exactly does B148E-55 (Not Configured) mean on this vehicle, and why would IDS abort both LIN initialization procedures?
Could a fault in the IPMB module or its communication with the front camera cause the camera image to remain blue?
Is LJ3T-19H222-AA a compatible replacement for LJ3T-19H222-AB, or could the different suffix be causing this issue?
Is there a specific diagnostic procedure in Ford IDS that I should follow to identify the root cause?
I don’t want to start replacing more parts without identifying the actual problem.
Has anyone experienced similar issues on a 2020 F-150 Raptor or another F-150 with the same camera system?
Any advice, wiring diagrams, known failure points, or recommended diagnostic steps would be greatly appreciated.
Thanks in IMG_1396.jpegIMG_1307.jpegIMG_1160.jpegadvance!
101,364
60,451
SOBRaptor
