cookiehumper
- Joined
- Jan 11, 2017
- Posts
- 114
- Reaction score
- 53
They are strip LEDs I got them from F150LEDs.com pretty easy install took about an hour. Connected them to the wiring harness at the bottom of the rear passenger door. Took a while to find the correct wire for them to work with the unlock botton and door open. I am considering switching to have them on whenever the running lights are on. I like the lookI like your running board lights and would like to know-are they led strip lights and where did you get them? Where did you connect them to light as you open the doors?
What year is your truck? I think the ground was yellow/black can’t remember the other color. Might have been Grey with Purple or Pink stripe. The opposite of the instructions. Sorry I can’t remember, I tried like 20 lol. If I decide to go with them full time I’ll let you know the exact color. When I open it back upI like the look also especially the matching amber. I am meter literate but do you remember the wire colors you connected to for door open and unlock button. Just trying to save a little time. Appreciate the info on where you got the strips.
Also I remember it was down on the bottom of the wire bundle. If you are doing the meter thing it was easiest after I closed the door latch with the door open. Then you could see the volt meter drop to zero when the lights went out.I like the look also especially the matching amber. I am meter literate but do you remember the wire colors you connected to for door open and unlock button. Just trying to save a little time. Appreciate the info on where you got the strips.
