2019 Raptor P0234 Overboost after Turbo/Manifold Replacement
RDunn82
Southern Oregon
I have a 2019 Ford F-150 Raptor with the 3.5L High Output EcoBoost engine, VIN engine code G.
The driver-side turbocharger and exhaust manifold were previously replaced. The installed turbocharger is a Rotomaster K1030182N, and the replacement manifold is an unidentified AutoZone part. The original passenger-side turbocharger and manifold remain installed.
Since that repair, the truck has experienced:
  • Repeated P0234 overboost codes
  • Reduced-power or limp-mode operation
  • Significant power loss
  • Inconsistent boost
  • Poor throttle response
  • A restricted or “choked” feeling during acceleration
Confirmed physical findings include:
  • A broken passenger-side turbocharger-to-downpipe fastener
  • A broken passenger-side exhaust-manifold stud
  • A passenger-side exhaust manifold that appears warped, though it has not yet been measured
Possible causes include incorrect Raptor-specific parts, mismatched turbochargers or manifolds, turbocharger-control faults, or excessive heat and mechanical stress caused by improper fitment or operation.
Could a Ford technician or qualified EcoBoost specialist confirm:
  1. Whether the Rotomaster K1030182N turbocharger and unidentified manifold are correct for this engine and vehicle.
  2. The correct Ford OEM part numbers for both turbochargers and exhaust manifolds, including supersessions and side-specific applications.
  3. Whether incorrect or mismatched components could cause P0234, limp mode, unstable boost, reduced power, poor throttle response, excessive exhaust temperature, or abnormal mechanical loading.
  4. Which related components should be inspected or replaced, including wastegate actuators and controls, boost and exhaust sensors, turbo connections, downpipes, catalytic converters, oil and coolant lines, gaskets, fasteners, charge-air piping, intercooler, and related connections.
  5. Which post-repair tests should be performed, including part-number verification, exhaust and charge-air leak checks, wastegate testing, commanded-versus-actual boost comparison, review of control and sensor data, loaded road testing for returning codes, and confirmation that boost, power, and throttle response meet factory specifications.
My goal is to identify and repair any underlying damage, incorrect parts, or related system faults rather than replacing only the visibly broken components.
101,284
60,415
Gerth
