2019 "Live" suspension mods
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Posting a thread to start discussing mods for the new active suspension.
If there are sensors analysing where in the shock stroke the shock is, will we be able to add collars/Geiser/Deavers etc without ******** up the sensors' algorithms?
If the shocks are attaching differently will we be able to run existing rear bump kits or will we need to wait for redesigned 19+ kits from vendors?
Thanks,
K
murph145
Simi Valley, CA
Until it turns out to be frickin' awesome and all existing mods work. :p
I'm rolling the dice.
Haha that would be awesome.... Hopefully you will find that out and hopefully those mods do not affect the live shocks.... I guess someone will have to be the guinea pig and let everyone else know.
TEXAS MOTORWORX
Dallas, TX
Word on the street is (absolutely not gospel) that we will be able to continue modifying OEM shocks the way we always have. Rumored 2" or less front and rear. We do know that aftermarket shocks will be configured to work with this system (who knows how much those will cost).
Bump kits "should be ok" clearancing may drive a different design of the metal. However, the overall design aspect of the bump stop kit will still be effective.
-Hunter
WillieFlo
Houston
-Hunter
Hunter, so to me that would imply that I ready left 2.5 inch lift kit with 1 inch in the rear should still work?
TEXAS MOTORWORX
Dallas, TX
Well, you should never really consider a "top of strut" leveling kit, those have been proven to destroy the factory geometry as designed by Ford. They work well on any truck (F150, Silverado, Ram, Toyota) that suspension travel isnt critical.
But you should be safe with a coil adjustment collar, and rear leaf springs.
-Hunter
WillieFlo
Houston
-Hunter
Can you recommend a good option?
I just ordered a 2019 raptor and I am having the dealership install lift, new wheels, and 35 x 12.5 tires when it arrives in late December/early January. I only went with the ReadyLift SST 2.5 inch lift kit, since that’s what they have been installing on other 2018 Raptors on the lot.
Kahuna
Kahuna
The good option is never to have a dealer supply and install a lift for you.
Take delivery, drive it then wait to see what Raptor companies come up with for a lift. You want something that enhances performance, not destroys it.
TEXAS MOTORWORX
Dallas, TX
www.texasmotorworx.com
Come see us. We are in Dallas, but our biggest market is Houston surprisingly. We can get you taken care of and squared away. We have built every combination of Raptor on the road. SVC, RPG, Battleborn, HM, Rogue, ICON, Camburg... you name it, we've built it.
If it was me, I would follow Kahuna's advice. Scrap ALL dealership installed parts. We will most likely be tremendously cheaper and we know what the hell we are talking about. ;) If you want give us a call tomorrow and we can lay out a plan. 214-785-6568, Hunter/Sam/Jason can help with any question you may have.
WillieFlo
Houston
And why would you change out the brand new tires. The stock tires are within .1 of an inch to the 35 x 12 tires, and they are C range which will ride better.
I like the BFG AT's and used to use nothing but them for years on previous rigs(at least 10 sets), but for the last 15+ years, I've been using the Nitto Terra, then Trail, and now the Ridge Grapplers, because they clean out much better than my BFG AT's ever did with the dark Gumbo we have in many parts of Texas, and I love the more aggressive sidewalls.
Also, I'm going with 20" wheels, instead of the smaller OEM 17" because I want to get the Vorsteiner Venom Rex on there. Just my preference.
I've had 18's on my Nissan Titan for 10+ years, and wanted a bigger wheel on the new rig.
Truckzor
True 35s are typically closer to 1/2" taller than the 315s, which is barely noticeable. You don't need to install a lift to run true 35s on a Raptor. Hell, with some Geisers and Deavers you can fit 37s without a lift.
Don't lift your Raptor.
I repeat. Don't lift your Raptor.
zombiekiller
OG BooBooRunner
New Orleans
Ask the fellas at TMX to send you pictures of my truck. Yes, it's an 18, but you'll get the point. A little bit of an altitude adjustment and some new shoes is no sweat compared to bypass racks, mid-travel kits, fitting fenders and bedsides, etc, etc.
I brought my truck to Dallas from New Orleans because TMX knows their shit.
I would never let a dealer sell me or install anything aftermarket or performance part oriented.
Take it to the guys that pay their bills by building badass trucks.
WillieFlo
Houston
Thanks for the advice guys!
Zombiekiller, I went to their website. Is yours one of the trucks on there?
zombiekiller
OG BooBooRunner
New Orleans
There are some pictures of the tmx Instagram, and on my Instagram.
I have a build thread on this site too.
Truck will be done as soon as the shocks show up from king for the front.
My truck is the magnetic one with the Robby woods carbon fiber on it.
WillieFlo
Houston
Thanks Zombiekiller, didn't see yours with the RW CF kit yet, but I saw the TMX Raptor on Instagram. Do you have Venom Rex 601's on yours by chance?
Another question on the Geiser progressive springs. I have progressive rate springs on my Polaris RZR because I had a full cage custom built out of heavier tubing, and didn't want to lose my clearance and jumping abilities. Since I'm planning on adding the ADD Stealth Fighter bumper in front, will the ride quality pretty much balance out?
zombiekiller
OG BooBooRunner
New Orleans
Thanks Zombiekiller, I saw the TMX Raptor on Instagram which looks to have 37's, correct?
Yep. Now sporting 37" generals
WillieFlo
Houston
I see. I want to stay with 35x12's since I've got a 25 mile commute each day/each way to work and prefer a little better gas mileage. Adding weight with the bumpers already, so I don't want to load it down with too much more weight.......but do want to get at least 1.5" in the front to counter sag from the bumper and settling in.
So, it looks like you guys convinced me on the Geiser springs! Now, if only I can find someone who has a set in stock before my truck comes in! Geiser is currently out of stock, and I'll bet most websites don't keep them in stock, but instead order them from Geiser to ship direct to customer as ordered.
Thank you all for the advice in this forum! Good to hear from you guys who've already been there and done your beta testing for us newb's.....
Members online
101,067
60,235
bbam
Latest posts
