GEN 2 2019 alignment
0-60 freak
Can somebody please help ASAP, I'm putting my suspension components on as we speak and I noticed that there is not eccentrics on the front control arm bolts, it is a perfectly symmetrical round Bolt, there is a slot in the frame rail that I suppose you can loosen the bolt and use a pry bar to adjust as you need but my 2018 had the oblong shaped thick eccentric washer, has anybody experienced this? Please advise
Sent from my SM-N950U using Tapatalk
brettmess24
I believe you are talking about your lower control arms?
What are you doing exactly?
If lifting the truck with shocks or adding UCA,s bring the LCA, to the most outward setting and drive to your alignment shop.
