GEN 2 2018 Steering Wheel Paint Chip
wmb3
St. Louis and Milwaukee
Hi: See photo attached. The Grey paint on my steering wheel is starting to chip or fade. Does anyone know what color I need to touch up this paint. Is anyone else having this issue?
Guy
Pop the trim pieces off, light sand them, and paint them magnetic grey.
any touch up paint you put on there is going to stand out like a sore thumb.
alternatively you can take it back to the dealer and try to make them replace it under warranty. You could replace it from TASCA or eBay too.
CoronaRaptor
CANADA
Are you out of the 3 year warranty period yet? A really good detail shop could probably fix that for you, I haven't got a clue, other than trying to match it up at an auto parts store.
FordTechOne
Detroit
That does not appear to be a chip/flake caused by a defect; it has the characteristics of an abrasion/damage. As the others mentioned, you may be able to touch it up yourself.
I lack the fine talent to correct something like that and make it match. I think @Bhollier did a pretty full trim pull and paint and I think if I were in your shoes I’d pull it, try to get a body shop to paint match and air brush the whole thing. I can air brush but corrections are just too much of a chore to me.
Bhollier
You are correct. I pulled all my interior trim pieces and had them painted piano black. Also had each of parts ceramic coated so they wouldn't scratch or chip.
Sonicsunspot
KC
pull carefully, the trim piece comes right out. no screws
Just curious and asking those that have tried this, did the trim piece really just pull off the wheel? I watched a couple of videos where they had to remove the airbag and the wheel to do this. Looks like if you pop the trim and unplug the connectors the airbag and wheel may not have to be removed.
FYI - my trim piece is also looking bad so I am wanting to paint or swap it. Not too fond of messing around with the airbag - I try to avoid things that explode when I don't want them to go bang.
