2018 F150 Raptor oil pressure question
kleztune
Hungary, Europe
Greetings, everyone!
I’ve been reading the forum for weeks, but unfortunately, I still haven’t found a solution to my problem, so I decided to write a post.
I’ll give a general overview of the car. 2018 F150 Raptor with 92.000 miles on it. I bought the car and (it was in good condition) I performed a full service on it. There was no phaser rattle, and the car made no bad sound at all. There wasn't even a single error in it
We replaced the entire timing system with upgraded phasers, (chains, tensioners, solenoids), and brand new oil pump, oil cooler, oil pressure sensor, water pump and pipes, thermostat complete with house, new coolant, new expansion tank. Unfortunately, my valve cover was cracked, so we put new left and right valve cover, new spark plugs, new coils.
We found some tiny metal fragments in the solenoids, so just to be on the safe side, it also got new connecting rod and crankshaft bearings.
(Naturally, everything received fresh oil,(trans, diffs, brake etc) though this won't be related to the fault.)
I use and service race cars, so I’m not really a fan of 5W-30 oil for an engine that runs this hot, that’s why I went with Motul 8100 5W-50 instead. (Although I did test the car with both.)
The car has no faults, makes no strange noises, and runs properly, however, I don't like it when I can't see the car's actual data, which is why I installed a Banks gauge.
That’s when I started getting concerned, since my oil pressure with the engine at operating temperature and under full-throttle acceleration, is between 50-60 psi. ( If I really push it, it can drop even lower than this.)
At the factory idle speed (650 rpm), I measured a pressure of 9–12 psi; we increased the idle speed to 850 rpm, at which point the reading became 12–18 psi. (98 degrees water, 96 trans temp) It can reach 70+ psi during a cold start.
If I use it normally, these values are better, but unfortunately it’s not really good. We tested by disconnecting the two stage oil solenoid and attaching a dummy, this eliminates the error, and the oil pump switches to "high" mode, but with these same values. At 1500 rpm, the engine can produce over 30 psi; during normal driving, it stays in the 30–45 psi range.
We’ve changed the oil several times, along with the factory oil filter (we even tried 5W-30), but we keep getting the same values.
Could anyone perhaps offer some guidance on where to start looking for the fault?
Roush2568
FRF is not for the weak
Colorado
I don't believe you have a fault. The Raptor oil pressure is controlled by the ECM. It will increase oil pressure as needed based on different parameters its reading.
Example: I can be doing 80mph with little to no load, steady speed and have 15psi of oil pressure. Increase throttle input some and it jumps to 48psi+
I run Mobile1 0w40 FS in my truck year around.
dsiggi
Detroit
Also they raised the hot idle oil pressure in the latest factory cal that solved the cam phaser issue to around 30 i believe. Id have to check all my pressures in forscan at the different conditions you state, but all seem about right except hot idle, you may not have the latest cal.
Roush2568
Colorado
I do have the lastest phaser software update and my hot idle oil pressure isn't nearly that high. I believe its around 15-22psi depending if the AC is on or not. I personally think 5w50 is way to thick of oil for the 3.5 Ecoboost.
kleztune
kleztune
Hungary, Europe
Thanks for the answers! Technically my car isn't regulating the oil pressure right now, since the two-stage oil control solenoid has been bypassed and it’s running in constant "high mode", delivering as much as the pump can handle. I wouldn't think the brand-new pump is faulty, nor that it's sucking in air, since the oil pressure isn't fluctuating. It’s more like the pressure is being lost somewhere in the engine (There is no oil leaking from the car anywhere, and we also replaced the crankshaft oil seal when the oil pump was changed.)
Or I’m not yet sure whether this engine controls oil pressure another mode, or how accurate this oil pressure PID actually is.
dsiggi
Detroit
hmmm i need to check mine again, but i swear once it goes past like 190 temp , the oil pressure jumps to about 28-30 at idle
Roush2568
Colorado
Its been a while, I could be wrong? I have a 180° thermostat. It never gets to 190° at idle.
dsiggi
Detroit
eh gives me another reason to plug forscan in and look at some things.... I find looking at things is never bad,
ya know like the Schrader valves in my rebuilt fox shocks that were finger turnable and had walked their way out..... things like that.....
kleztune
kleztune
Hungary, Europe
why tho? Ive never over heated with a 195. Ran other trucks each year in the desert heat, no issue....
Because, I’ve noticed that the oil pressure values remain good until the coolant temperature starts reaching the 204-212 range. (as a result, the oil will also be well over 215+)
dsiggi
Detroit
Interesting, do you have some examples, and what do you define as "good"
dsiggi
Detroit
so i just checked forscan, and yes, my hot idle oil pressure hovers right around 30 +-2 ish psi. If you dont have the newest calibration for the phasers, it will be much lower at hot idle.
Roush2568
Colorado
I did some testing for that new app a member developed this morning and this is my warmed up oil pressure on my COBB. 3616.jpg
kleztune
kleztune
Hungary, Europe
When my water temperature is around 170, I also get 25–30 psi of oil pressure, but the water temp around 200, oil press around 15 psi.
101,364
60,451
SOBRaptor
