2017 Raptor Transmission Slip & Overheat
KyekyeG
Hello Y'all
I have a G2 Rap and have been experiencing some major transmission issues since 1800 Miles. Hopefully this post can help out others if you start having these issues and for gosh sake you dont have them.
At 1800 miles driving on a the free way going on a long trip (3hours into my drive). The transmission temp spiked to 240dgf. I pull over let it cooled and continued to the dealer. But then a grinding noise presented itself going to the dealer.
They replaced transmission cooler and torque converter.
After that my transmission overheated again on another trip about 2 hours into the drive and started slipping gears.
I been to the dealer 5 times after the second vist and they cant replicate the issue at all because they wont test drive a vehicle over 50miles... Well 35 miles on an ambient air temperature transmission gets it to normal operating temp. So that gives 15 miles of normal driving conditions. I explained to multiple dealers that these issues occurred at 100+ miles of driving
Both dealers told me to bring it back when it fully breaks.
I had it towed it twice because half the transmission fluid came out the vent when it gets to 245 255. They said that they can't find any issues, added more fluid and sorta cleaned the bottom of the truck.
My next step is to contact the BBB and see what they can do. I called ford customer service and they told me to take it to another dealer. I feel like this is just going to take me down the same path i went through with the first two dealers.
I'll keep y'all update.
jabroni619
That does sound quite frustrating. Maybe video document one of your longer drives so you can show them exactly what's happening?
kandewinn
Agree, melt the tranny, you don't want to keep that one anyway. They'll fix it then. Along with anything else that breaks along the way as a result. Especially since you have it recorded at two different dealers with no resolution.
K
KyekyeG
I have showed the dealers vidos and pictures about this but they need to see it them selves to aprove work but none of them even know whats wrong with it. Fords engineer even didn't know whats wrong or why its doing it.
I tried to melt it down but it goes into a silly limp mode to save itself from further damage...
jabroni619
Can they not pull codes to at least verify for themselves there is a problem? Or does this particular issue not throw a code? It seems unlikely that it wouldn’t if it’s going into limp mode.
K
KyekyeG
The dealer had verified high temps and limp mode codes. But they can't figer why. But to fill it back up with fluids and call it quits.
They thought it was a bad computer that time and replaced it.
MGD
Banned
Time for another dealer.
tmd11111
If the trans and torque converter were replaced and its still doing the same thing then it has to be a clogged or pinched oil line or cooler.
