2017 Raptor R1Concepts Performance Brake Packages NOW AVAILABLE!
Discussion in 'Freedom Motorsports' started by [email protected], Feb 22, 2017.
  1. Chris@FreedomMotorsports
    [email protected] FRF Gofur Supporting Vendor Supporting Member
    45
    3,035
    2,495
    Oct 4, 2012
    Woodlawn, Virginia
    2017 Ford Raptor R1Concepts Performance Brake Packages NOW AVAILABLE
    [​IMG]
    PLEASE NOTE: This image does not show the 6-lug Raptor Rotors.
    R1Concepts "Premium" - Double Cross-Drilled & Slotted Brake Rotors
    R1Concepts PREMIUM SERIES BRAKE DISC
    WITH BLACK MILITARY GRADE E-COATED HUB FOR INCREASED LONGEVITY
    R1Concepts Premium Series Cross Drilled and Slotted Rotors offer outstanding stopping power and performance as well as dependable longevity.
    Product Description :
    1. Cross-Drilled and Slotted Design
    2. Drilled holes provide maximum air circulation for increased cooling
    3. Holes are countersunk which reduces heat build up
    4. Exclusive R1 Concepts Diamond Slot increase brake pads bite
    5. Diamond Tip use as indicator for brake rotor wear
    6. Black E-Coating Gives Long Lasting Corrosion Protection
    7. High strength cast iron discs
    8. Direct Fit OEM Replacement Brake Rotor
    9. Double disc ground finish reduces rotor vibration
    10. Meet Or Exceed OEM Standards For Excellence
    11. Mill balanced brake rotors ensures long lasting durability
    12. Superior Machined Surfaces That Provide Smoother And Quieter Stops And Longer Brake Pad Life
    Note: R1Concepts Premium brake rotors are machined using a G3500 grade High Carbon Metallic compound which is much stronger than other offered rotors on the market today since the vast majority of them are cast from G3000 grade cast iron. Stronger, longer lasting and offering better cooling properties than cast iron, the Premier series rotors are by far the better choice for all Raptor Owners for increased braking performance and overall longevity.
    [​IMG]
    POSI QUIET CERAMIC BRAKE PADS
    Posi-Quiet pads are the only full-line of aftermarket pads that are scorched. This OEM process enhances key friction performance levels, removes any impurities in the friction compound, and prepares the brake pads for immediate use. Scorching raises initial cold effectiveness, stabilizes friction levels right out of the box, provides consistent performance across entire operating range.
    Features:
    • Longest wearing, most advanced material available.
    • Lowest Dust.
    • Stable Friction Performance Across Wide Temperature Range.
    • Pad shims are either staked-on, drift-lock or application specific shims custom fit for a secure 'no slip' attachment.
    • Application include import and domestic cars, trucks, and SUVs.
    • No Break-in Required.
    • Scorched to eliminate the break-in process.
Share This Page
