2017 Raptor Intercooler relocation kit for winches from ADD
Mesa, AZ
Want to run a winch on your 17 Raptor? There simply isnt room for it with the facotry intercooler. ADD offers a relocation kit for an all new aluminum intercooler to allow for a winch to fit. This kit also gives you more cooling than the factory setup!
http://www.addictivedesertdesigns.com/2017-ford-raptor-intercooler-kit-AC11151203/
Addictive Desert Designs
Mesa, AZ
Ok so educate a new raptor owner on this.
This relocated the whole radiator so a winch can fit?
No this relocates the intercooler for the turbos. Factory intercooler sits right behind the factory bumper. You cant fit a winch back there, & even if you could, it would block the airflow to it.
Mesa, AZ
so ADD, are you saying that the new Raptor ADD bumpers w/ winches require the intercooler relocation kit ?
Correct, with the factory intercooler, there is no room for a winch. Even if you custom built something to mount one in there, it would block airflow to the intercooler.
FordFanStan
Do you have any metrics other than "also gives you more cooling than the factory setup"? I'd love to see some IAT1/2 before after temps with consistent tests/environments if possible. Also what manufacturer makes the actual IC you're using?
Thanks
BTW, looks like a nice product.
