From the very beginning, I had a suspension issue that only showed up on gravel or sand. In the city and on the highway there were no problems at all. But when spinning the tires in the sand or driving on washboard gravel roads, a severe rear axle wheel hop would occur. The diagnosis was obvious - the shocks lacked rebound damping. Considering the first owner of the Raptor only serviced it at the dealer and never touched the suspension, with this mileage the shocks were clearly begging for a rebuild.
I wanted to get the rebuild done at the factory, but I still needed something to drive so I postponed that idea and started looking for a replacement suspension kit in the meantime.
Then, a set of Live Valve shocks popped up, taken off from a 2019 model with only 15k miles on them. They came fully complete with solenoids and protective shields. I got them for just $1,000—it was a steal I couldn't pass up.
So, what’s next? I needed some way to control them!
I bought a factory 2019 vehicle dynamics control module on eBay just to use as a donor. I had neither the time nor the desire to deal with reverse engineering, so it was faster to build a custom controller from scratch. Spoiler alert: it turned out better than I expected!
I started designing the schematic based on a 32-bit microcontroller. I designed the power stage using a more modern approach with smart driver ICs rather than the old-school layout used in the factory controller.
Then I routed the custom PCB and ordered it from the fab. I kept the dimensions exactly 1:1 with the stock board, hoping to cram it into the factory control unit box, which has a perfect aluminum baseplate for dissipating heat from the power drivers. A week later, I had the board in hand. By that time, all the necessary components for assembly had arrived as well. Soldering took less than an hour. Then came a few days of software development... First for the controller itself and then a PC application so everything could be conveniently tuned on the fly.
During software debugging, a few hardware issues with the board surfaced so I had to make some tweaks and order a second revision, which ended up being the final one. After a few days delay waiting for the new PCB revision to arrive, everything worked flawlessly on the bench. It was time for in-car testing.
The shocks on the truck had been swapped a couple of weeks prior. Of course, without the controller hooked up, driving felt like all four shock shafts were seized. The swap itself was straightforward, the only new hardware needed were the lower shock bolts as they are torqued to a pretty high spec. Interestingly the factory bolts hadn't stretched.
By this point, I had completely finished the wiring on the Raptor. For the controller's power source, I tapped into the battery junction box under the hood, used an empty fuse slot, crimped a terminal, and routed the wire out into the factory harness. I laid everything out neatly and the new harness entered the driver’s footwell through the OEM rubber grommet.
My controller fit perfectly into the original Ford housing. The photos show a side-by-side comparison of the components on the stock controller versus the custom one.
I used the exact same connectors as the OEM module. Once assembled, the only external difference is the presence of a USB port on my controller for PC connection.
Since this system wasn't available from the factory in 2017, there were no mounting points for the control module housing. Well, there might be one, but it’s hidden under the parking brake mechanism so mounting the module there wasn't an option. I started brainstorming different locations and the best option was placing it next to the trailer control module. I took off the stock mount, bent an aluminum plate to create a custom mounting bracket for my controller and riveted it all together. It mounted up beautifully and I routed my wiring right alongside the trailer module harness. Pure OEM+ look.
First power-up in the truck, and... the bench tests didn't lie. Everything works.
As for the overall functionality, here’s what I ended up with:
- Control modes are switched directly from the steering wheel alongside the factory Terrain Modes. Each Terrain Mode can be individually tuned via the PC software.
- Hardware-level driver diagnostics for each solenoid are implemented. Whether it’s an open circuit, a short to ground, or a short to battery — the software throws a specific DTC inside the program, while the dashboard displays a generic system fault message, exactly like the stock setup.
- In every mode, base stiffness can be adjusted individually for each shock, plus dynamic compensations for braking, acceleration, cornering, and G-forces. All this data is pulled directly from the CAN bus via the original control modules. I implemented this algorithm just in case I want to play around with deeper tuning later, but for my current needs, I see absolutely no reason to use these compensations. Body roll and diving under acceleration and braking are actually more of a useful feature for me rather than a drawback.
- The board is fully prepped with power and signal traces for ride height sensors. I skipped installing them on my setup, though
- Purely for data logging purposes, I added a mathematical model to calculate the shock oil temperature. It will be interesting to monitor this while driving.
That’s all for now. I just need to find some time to hit the trails for the final tuning.
I'll definitely post an update with the results, but even now it’s a pleasure to daily drive—the suspension soaks up everything, just like it did on my old blue shocks.
