2017+ Fox Raptor Coilovers!
SDHQ
GILBERT, AZ
These just landed here at SDHQ!
Add adjustability and increased cooling efficiency to your 2017 Raptor. FOX's New 3.0 Coil-Over Internal Bypass kit for the front is paired with an all-new recirculating finned reservoir and DSC adjuster
https://sdhqoffroad.com/collections/fox-shocks-ford-raptor
Jeff-Ohio
Cincinnati
2017+ Ford Raptor Front Coilover, Internal Bypass, 3.0 Series, R/R, 8.1", 0-2" Lift
Is that what I need to purchase if I want the ability to adjust compression and rebound? I was hoping there would be a cheaper option to accomplish that goal.
SDHQ
SDHQ
GILBERT, AZ
These coilovers will only allow you to adjust high speed compression and low speed compression, not any rebound. The rears (bypass) will give you compression and rebound adjustment.
SDHQ
SDHQ
GILBERT, AZ
Had a bunch of fronts and rears just land! Call the shop to get your set ordered up!
480-633-2929
