2017 Ford Raptor Swaybar Disconnect Flex Test
Trick.Raptor
The Cracker Raptor
Santa Maria, CA
1.5" of additional flex isn't worth it. If you have to make any sudden evasive maneuvers, you will regret not having the anti-sway bar connected.
Define sudden evasive maneuvers? Something like a moose test?
I've had no sway bar now since October and other than more Raptor lean in the corners the Raptor handles as good as before with the sway bar. Corners at speed with lots of drifting made no difference in handling other than the lean.
I get what you are saying I've just not heard of anyone who had an accident because of it.
The good thing is the entire sway bar and be removed and installed in about 10 minutes. At least it was that way before my SDHQ alignment cam install. Those bolts cover the sway bar bolts :(
Aaron
Meme Corps Commandant
WA
I run with no swaybar as well and love it. If you're running extra preload on your shocks the lean gets less noticeable. I can still rail into Starbucks drive thrus just fine without it.
I don’t support this modification. It compromises cruising and parking in mall parking lots.
Starbucks has drive thru?
Aaron
WA
You're saying that you go into the lobby like a peasant?
It also really helps with taking those mall speed bumps. Mall crawling = enhanced
oxfordraptor
I assume you're in Mall/Starbucks mode when this goes down so you don't get your hands dirty.
