2017 ford raptor magnum force stage 2 pro dry s cold air intake system
Discussion in 'Southern Car Parts' started by Southern Car Parts, Jun 27, 2017.
  1. Southern Car Parts
    Southern Car Parts Supporting Vendor Supporting Vendor
    75
    7
    Jun 9, 2017
    Salem, Ohio
    2017 FORD RAPTOR MAGNUM FORCE STAGE 2 PRO DRY S COLD AIR INTAKE SYSTEM - $799.00
    The 2017 Ford Raptor Magnum FORCE Stage 2 Pro Dry S Cold Air Intake System outflows factory intake by 67% with its 3-1/2in mandrel-bent, brushed aluminum design intake tubes for balanced intake pressures and maximize airflow and velocity. Its aluminum one-piece heat shield utilizes stock mounting locations.
    Dual Inlet Large 3-Layer "Oil-Free" Performance Air Filters:
    This intake system utilizes oil-free, large 7" tall radial flow performance air filters with 3-Layer progressively finer porosity synthetic media for maximum convenience.
    Top Mounted Heat Shield Design:
    aFe developed this aluminum heat shield to snap onto the top of the lower half of the factory air box to provide a hassle-free installation utilizing factory mounting locations.
    Equal Length Intake Tubes:
    Dual mandrel-bent brushed aluminum equal length intake tubes are designed with an H-pipe to balance intake tube pressures and maximizes airflow and velocity.
    Hassle-Free Installation:
    All clamps, couplings, and hardware are included for hassle-free installation. This is a direct bolt-on kit that requires no cutting or drilling on factory parts.
    Note:
    This product is not currently CARB exempt and is not available for sale in California or for use on any vehicle registered with the California Department of Motor Vehicle.
    APPLICATION: 2017 FORD F-150 RAPTOR
    [​IMG]
    [​IMG]
    http://www.southerncarparts.com/2017-ford-raptor-magnum-force-stage-2-pro-dry-s-cold-air-intake-system.html
  2. Southern Car Parts
    75
    7
    Jun 9, 2017
    Salem, Ohio
Share This Page
