2015 GLRE Time Attack Series presented by Baja Coyote Offroad
Kanakry
Great Lakes Region
Improved by popular demand is the original timed event for Ford Raptors. As a participant you will be able to compare your time on a set course to the time of other Ford Raptors. The course will be specifically setup for modified and stock Raptors alike. The Time Attack Series in 2015 will be a combination of three different off road tracks.
Each track will have a practice session before the actual timed runs. Timed runs will be a minimum of 3 laps for a combined time.
The GLRE Time Attack Series tracks and dates.
May 23-24th- Phoenix Short Track, Stuebenville, OH ***Registration closes on 5/11/2015
Sept 5th - Rausch Creek Off road Park, Tremont, PA * this is a 1 day event
Oct 10-11th- I96 Speedway, Lake Odessa, MI
Oct 11th- Championship Banquet, Hilton Grand Rapids
Classes:
Open Class: Open to all trucks willing to compete against the best drivers
• Unlimited modifications
• Truck must have started out as a production Ford Raptor prior to modifications
Sportsman Class: Open to all Ford Raptors that fit the following criteria
• Naturally Aspirated
• Stock or Bolt on suspension mods* Dual shock front suspension not allowed
*Sportsman Class participants are not required to partake in lap timing*
Required items:
Helmet: SNELL 2000 or newer
Mounted Fire Extinguisher
Working Seat belts* Must be worn at all times!!!!!
Series Details:
Every race will count towards an overall series point total. Plaques for top 3 finishers in each class will be awarded after each time attack. Overall Trophies and raffle will be at the championship banquet.
Timing:
Electronic timing via ALGE Timing system and photocell eyes. Same timing system used in profressional sporting events which require timing down to .01 of a second.
Penalties:
Cones- 5 second penalty for each hit cone
Off track with 4 tires- 10 second penalty for each off track incident in which all 4 tires are off track
Race Points Details: The following series points will be applied to each class of each race to determine overall series points. No Shows are assigned 0 points. Winners of each class will be the participants with the most points.
Place 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
Points 100 80 60 50 45 40 36 32 29 26 24 22 20 18 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1
Registration: Time Attack Series
Track sponsors:
Track #1
Track #2
Track #3
Banquet Sponsor
Other Sponsors
WRCRaptor
Great Lakes
Dam Dam Dam! Work trips on all of them! The I-96 one was fun. The format of these also gives you time to wonder and get a good look other trucks unless you break something then you will get to meet more people since everyone will help you fix it.
