Ihad the blower motor box of marbles sound in mine too. Heres my DIY. PITA but easy fixSo I found a spring for $11, put it all back together, and it runs perfectly. I do not have a tag on it, so I cant get out on the highway but it drives fine around my neighborhood. Problem solved! Now, on to my next two issues:
Both should be quick and easy fixes.
- It has an aftermarket amp and the left speakers do not play
- The climate control fan has something in the squirrel cage that sounds god awful... like a box of marbles when the a/c or heat is on. I saw a video and apparently its a common problem (plastic part from the blower/recirculate door falls into the fan).
FWIW: I posted on here because this forum provides a wealth of information that ranks high in Google searches. The info that I find on here is GREAT! If nothing else, I hope that my post helps someone someday.
I didn't make a DIY or "how-to" post since there are plenty to be found already... BUT wanted to add that I am by no means a mechanic and I managed to do this myself in an afternoon with typical hand tools (mostly ratchets/sockets/extensions and torque wrench) and a couple of purchases at Harbor Freight (overhead valve spring compressor and leak-down tester).
If anyone has questions, I'm more than happy to respond.
Blower Motor Vibrates the cab, Blend Door Broke, DIY fix it
Had this fun times happen las night on the way home. Whole cab started vibrating like one of @Oldfart good time goat rallies. Kinda thought I had reinitiated into the 6.2 window club......you never get over that feeling or concern of it happening again. there was really noting here about...
