2014 Gen 1 Sudden Misfiring and Brake Issues
ERICB100
Florida
Hi all... I am new to this forum and this seems to be the place to go for Raptor advice. I have searched for hours and cannot find something to help with my exact issue.
Backstory:
My gf's ex-husband got a new truck and gave her son his 2014 Raptor SVT. It is a one owner truck with 251K miles on the 6.2L beast. I am told it has been well maintained and his son drove it for about a year with no issues.
From what he tells me: One day while driving about 30mph, the truck suddenly began to misfire and the brakes barely worked. He had to pull into the first parking lot he could find.
He took it to 3 places including the local Ford dealership:
  • Ford dealership - "It needs spark plugs, coils, and ignition wires for $2,340"
  • Independent shop 1 - replaced the plug and coils for $1100. When that didn't fix it: "it needs cam phasers" for $4K to $5K more
  • Independent shop 2 - "it needs a new engine" for about $15K
4/15: EDITED THE DIAGNOSTICS HISTORY (INFO IN BLUE) AFTER SPEAKING WITH THE PREVIOUS OWNER TODAY
After a month of no progress and he needed a dependable ride, he threw a for sale sign on it and got no bites. I bought the truck from him so he could use the money for a new ride.
An AAA flatbed brought it to my house. The battery was DEAD as a doornail. I am not sure if it now has a new parasitic draw that appeared with the sudden onset of engine issues, or if someone left the key on. It did not previously have a parasitic draw, but it was also towed to 3 shops and then to my house. When the wrecker dropped it at my house, he turned the key on to shift it into neutral (had to use a jumpbox to do that) and he literally left the key fully on when he walked back to his truck and left.
I used a jump box to start it and it ran awful. It stumbles and stutters and acts like its firing on only 4 cylinders. In drive, it has little power but will occasionally surge. The brake pedal is hard and the brakes barely stop. The truck having almost no brakes combined with the occasional unexpected engine surge made it sketchy as hell backing it into a tight space next to my boat.
I found only 2 codes using ForScan:
  • P0230-14 Fuel pump primary circuit (short to ground or open)
  • U0422-2E Invalid data received from BCM
My thoughts: It is highly unlikely that multiple plugs or coils failed simultaneously. I do not believe any of the shop's diagnosis. My initial thought was fuel starvation or vacuum leak.
What I have tried so far:
  • First of all, I threw a charger on it. It has a Diehard with date code 10/25 an it seems to hold a charge just fine. It now starts the truck without a jumpbox.
  • Next, I confirmed that the fuel pump fuse is good (and has been relocated from 27 to 70).
  • I swapped fuel pump relay 8 with another identical relay.
  • I visually inspected the wiring harness along the driver's side frame rail from the fire wall to the FDPM and fuel tank. Looks fine.
  • I confirmed 14.4V to the FDPM, but I was only getting 13.1V dropping to 9.4V out of it. With the odd readings and the potentially unexplained parasitic draw, I replaced the FPDM. It didn't make a difference, the engine still stumbles and I had no brakes. I kind of figured maybe the FPDM varied the fuel pump speed using voltage so the output voltage was perhaps not an indicator of failure after all.
  • I removed the fuel pump fuse and cranked it over to remove pressure from the fuel rail. I re-installed the fuse and turned the key on. I can hear the fuel pump quickly reach pressure and turn off so I decided to move on and look for vacuum issues.
  • I sprayed the intake and vacuum lines with carb clean while it was running and found nothing (no change in idle speed, no change in the crazy misfiring)
  • Next I pulled the evap purge valve from the intake and plugged the hole in the intake. It didn't help the misfiring, but it may have improved the braking...
    • I now seem to get one good brake pedal before it starts to fade and get harder to press. Maybe it was this way all along and maybe the evap purge valve didn't make a difference... I'm not sure.
  • Next I shifted into 4x4 to engage the hubs which I was told could help with vacuum. It shifted into 4x4 fine, but later it could barely shift back out to 2 wheel drive... lots of grinding and noise and it took a few minutes to get there.
  • I have since looked over the vacuum hoses and see nothing obvious, but I still lean toward a vacuum issue since the brake pedal is so hard to push.
Summary:
The truck ran fine, then had a sudden onset of misfiring and simultaneous loss of brakes while cruising down the road at 30mph. Prior to the issue appearing, the truck had sat for 2-3 hours, was then started, and had only driven about 2-3 miles when the issue suddenly appeared.
I am kind of stuck. Any ideas?
Thanks!
Highwayman
YUCAIPA
Sounds like a bad brake booster.... Hard to tell not looking at it. Really need to at least put a vacuum gauge on it and see what that looks like. Low vacuum, fluctuating, etc....
ERICB100
ERICB100
Florida
I just confirmed that it does hold at least some vacuum at the brake booster. After sitting for about an hour, I disconnected the small hose on the right side of the brake booster and there was still vacuum present. The small hose branches directly off of the large hose that operates the booster. I can try disconnecting and plugging the hose that operates the brake booster.
Edit: I just removed and plugged the large vacuum line that runs from the intake manifold to the brake booster and started the truck. It made no difference. I do not have a vacuum gauge, but there is vacuum present. It's not crazy strong vacuum, but I am not sure what it normally would feel like. When I remove the plug and leave that large vacuum hose wide open to suck in air, it makes no difference in the way it runs and idles. It runs very rough.
So the truck seriously barely runs. I am not sure if low vacuum is the cause of the engine stumbling or if engine stumbling/barely running causes the low vacuum?
Edit 2: Bought a vacuum gauge that will be delivered tomorrow.
ERICB100
ERICB100
Florida
This is a pic of Betty being delivered. She looks cool, but she'd be a lot cooler if she ran.
I have noticed that if I start her and do not touch the pedal, the idle is not that bad. Once I touch the gas, it runs worse and does not return to a somewhat smooth idle... it just seems to get worse the longer it runs.
ERICB100
ERICB100
Florida
I was able to pull up brake booster vacuum in ForScan:
  • When the truck first started, it was reading around -15 mmhg
  • As it idled (rough idle), it fell to around -11 to -12 or so.
  • When I hit the brakes, it dropped to -9 and the truck really began to idle rough at that point.
  • When I hit the throttle to get the RPMs up, it would go no higher (or lower actually) than -12.
  • When I let it return to an idle, the RPMs dropped really low as the engine really stumbled to the point it was barely running, but the vacuum didn't drop below -9... and then the engine sputtered/died.
I hope some of this is helpful.
Nex
RIP CoronaRaptor
Behind Enemy Lines
How's the throttle position sensor look? Runs fine at idle, then stumbles when adding more air. Low vacuum could just be due to the rough idle.
A compression test and leak down test would be good. And new spark plugs while you are there. All 16 of them.
Sounds like a sensor problem. ECU is guessing where the engine is.
mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
There has to be a good qualified shop in your area that you could take it to. Guessing and trying to fix it by throwing money and parts at it not to mention all the time involved. Hate to see you get discussed with the truck over this.
Highwayman
YUCAIPA
You should be at 20 idle. You need to hook a vacuum gauge to the motor and see what it is there and confirm whether its losing from the booster or thats what its actually getting to the booster and its motor issues.
ERICB100
ERICB100
Florida
So I likely have a broken valve spring:
While laying in bed last night, I was searching the interwebs and finally came across a video from someone who had identified and resolved my EXACT issue:
sudden misfires, "running like a 3 legged dog", and brake pedal that felt like it had no vacuum with truck very hard to stop. The symptoms are laid out in the first 30 seconds of the video. At the 4 minute mark, the mechanic says "man this truck is shaking really bad" (yep! I can relate!) The motor in the video seems to be running better than mine, but I FaceTimed my truck with a friend and he didn't think it ran as bad as I did in person. The only difference: the truck in the video is throwing misfire codes and he has what he describes as "really nasty knocking" which sounds like metal banging on metal.
FWIW: While my truck misfires badly, I have no loud metallic banging sound and my truck is not throwing misfire codes.
I have come across broken valve spring stuff about this specific engine quite a few times, but here is the YouTube video that has me thinking bingo! Even people in the comments: "Buddy's 13 6.2 started running like shit and knocking this morning with whierd brake shit accompanying. Found this video and pulled valve covers broke spring cyl 8! Thank you!"
Unfortunately, ForScan cannot do relative compression testing or power balance testing so I am going to have to pull the valve covers, probably today. This truck is tucked out of the way behind my house and I have plenty of time to tackle this myself. I can order genuine FoMoCo valve springs and seals individually for $31 on eBay and I am willing to give it a go. If there is a better place to buy them, please feel free to let me know.
ERICB100
ERICB100
Florida
And bingo is correct! #6 intake valve has a broken spring. Photos are below.
To decide which valve cover to remove: I fired it up and used a wooden painters pole as a redneck stethoscope. I held one end to the passenger side valve cover and the other end against my ear... it was pretty quiet. When I did the same for the driver's side, I could hear a distinct rhythmic ticking sound. It was surprisingly not very loud, but it was very clear. I was hoping it would be on the passenger side due to space, but I think the driver's side is actually maybe easier. Two bolts and 1 hose clamp removes the whole breather and coolant reservoir which gives plenty of room. The back two bolts on the valve cover take some contortion, but removing the valve cover was not hard. Now I just need to order the part. It would be great if an auto parts store open on Sunday had one.
NOTE: there was a lot of dirt/sand/leaves on the valve cover and intake. I used the air compressor to blow it all off really thoroughly before I removed the valve cover otherwise, some of this may have ended up in the engine.
ERICB100
ERICB100
Florida
So I found a spring for $11, put it all back together, and it runs perfectly. I do not have a tag on it, so I cant get out on the highway but it drives fine around my neighborhood. Problem solved! Now, on to my next two issues:
  • It has an aftermarket amp and the left speakers do not play
  • The climate control fan has something in the squirrel cage that sounds god awful... like a box of marbles when the a/c or heat is on. I saw a video and apparently its a common problem (plastic part from the blower/recirculate door falls into the fan).
Both should be quick and easy fixes.
FWIW: I posted on here because this forum provides a wealth of information that ranks high in Google searches. The info that I find on here is GREAT! If nothing else, I hope that my post helps someone someday.
I didn't make a DIY or "how-to" post since there are plenty to be found already... BUT wanted to add that I am by no means a mechanic and I managed to do this myself in an afternoon with typical hand tools (mostly ratchets/sockets/extensions and torque wrench) and a couple of purchases at Harbor Freight (overhead valve spring compressor and leak-down tester).
If anyone has questions, I'm more than happy to respond.
RAPTORSV
S. California
Since Ford didn’t equip these models with a cabin air filter a lot of crap can build up in the HVAC fan over time. There is an aftermarket filter fix for this. You can see around the 18 minute mark all the build up in the fan.
OKflyswatter
Oklahoma
I’m far from a competent wrench turner, but from what I’ve seen that HVAC fan is a complete B to work on. Let us know how what you end up doing and how you resolve it. I’m dreading when mine grenades itself!
ERICB100
ERICB100
Florida
Yea buddy. Thats the wife’s lil rocket. Uni stage 2 R600 intake and an exhaust. Waiting for the clutch to go out cause they HATE tunes.
Warning: This is absolutely unrelated to this post or forum. Sorry!
#1: I see the Air Force logo. I was Army, but did spend about 6 months attached to a unit on Sheppard AFB in Texas. It made me regret my life choices. I had it made on that Air Force base! I felt like I was staying in a hotel. I was only a PFC and had maid service in my room!
#2: The Golf R is my son's. He's grown and gone, but I still help him wrench on it. His clutch is getting near the end of its life. He had a MK5? Golf GTi before this car and we replaced its clutch ourselves in one Saturday at my house (no lift). We haven't decided if we are going to try and tackle this one ourselves.
Our most recent projects on the Golf R:
Built a custom subwoofer box that holds a shallow JL Audio sub yet still fits below the false floor in the hatch above where the spare tire would be.
Installed a trailer hitch so he could get a cheap used non-running jet ski that we managed to fix in about an hour (I had cropped some of the previous Golf R photo to remove him and the ski)
ERICB100
ERICB100
Florida
I will take a few photos and will start a new post for that project. The guy in the video made it look simple, but he wasn't rolling footage throughout the entire project. He took short videos between the major work to just tell the viewer what "he had just finished". His video caught my eye because it is literally the EXACT noise that mine is making.
ERICB100
ERICB100
Florida
I'll check that out while I'm up in there. Thanks!
101,297
60,427
SVT4DGUY
