GEN 1 2013 Another Dealership Horror Story--Popping sound while turning
Mvick9
Mvick9
Ponchatoula, LA
What about the spindle / outer bearing ?
Coincidently I resorted to describing this saga to chatgpt tonight. It recommended to have the dealer inspect the splines and hub bearing assembly as they can be damaged during cv installs.
I'm also wondering if I'm just fighting a IWE system problem. It's not the typical grinding sound but I have been reading on other f150 forums that guys where having this clunk or pop sound from failed IWE systems.
I'm going to run it hard tomorrow in 2wd and 4wd and if I have time do some vacuum tests on the IWE system. I may have had an issue with it before the axle swap and the new axle with fresh splines is amplifying the sound. Idk
Roush2568
FRF is not for the weak
Colorado
How did the axle break? Perhaps you have front diff damage that only shows when your making a right hand turn and that inside tire needs to turn faster than the outside tire. Just playing the guessing game at this point.
Mvick9
Mvick9
Ponchatoula, LA
I had the dealership swap the axles because the boots had torn. My warranty runs out in August so I figured I would use it before I loose it. Other than the torn boots the axles did not show any signs of being bad, clicking popping binding etc.
Mvick9
Mvick9
Ponchatoula, LA
Alright, just took the truck out in a field. Pop sound is present while in 2wd and also 2wd with offroad mode on. Switching it into 4wd makes the popping sound alot louder and more intense. It is still only doing it while turning to the right but there is a big difference on the noise intensity between 2wd and 4wd. I then disconnected the vacuum lines and left the truck in 2wd. Popping sound is still alot more intense just like it was in 4wd. I reconnected the vacuum lines and left the truck in 2wd. First right turn was loud then all subsequent right hand turns produce the quieter less intense popping sound that I have been hearing. Now I'm thinking it is possibly messed up splines on the hub bearing assembly, or a spline count and pitch mismatch. I don't think newer axles would have a different count or pitch but who knows.
I need to do a vacuum leak test on the whole iwe system. I may possibly have a Crack in a line that allows vacuum to leak during a right hand turn. A leak along with messed up hub splines may be what I am fighting.
Bozz
Royal Smart A$$
Nashville, TN
Probably not related, BUT....
Just got my Raptor back for a new transmission. Was making weird noise that I narrowed down to IWE.....probably.....
Ordered new vacuum lines anyhow, old ones are 200k miles old. Haven't received/replaced vacuum lines yet.
Did an Adaptive Learning Table reset by disconnecting negative battery cable for 45 minutes. Noise is GONE!
101,329
60,419
clong18
