2012 conversion to 2013 OEM projector headlights
Discussion in 'Ford Raptor Problems and Questions Forum' started by jasfergus, Jun 12, 2019.
  1. jasfergus
    jasfergus Member
    5
    Sep 20, 2016
    Hello. I bought a one owner 2012 Raptor SCREW in 2016. The previous owner had upgraded the headlights to the 2013 Ford OEM projectors with a Morimoto relay and harness. He had to replace the relay once before I bought it and it just went down again. I contacted Morimoto and they said "the harness has been significantly improved" in recent years. Has anyone had experience with Morimoto recently or have another suggestion for a conversion harness. I would like to keep the 2013 Ford headlights.
  2. brink
    brink Member
    3
    Nov 1, 2017
    My morimoto has been fine for almost 2 years through Montana winters. The key is to use the grounds on the back of the radiator support and also I electrical taped the shit out of every connection to protect it from moisture and corrosion. I do carry an extra harness in the truck though so if the relay goes down somewhere remote at night i can change it out.
  3. viper238
    viper238 Member
    May 21, 2012
    Get some dielectric grease to put in the contacts/ connections and ground points. Clean up the grounds points with a little sand paper and put some dielectric grease on them. It will prevent corrosion/ rust and aid in connectivity.
Share This Page
