2010 svt raptor help
Discussion in 'Ford SVT Raptor General Discussions [GEN 1]' started by cookie47121314, Mar 18, 2017.
  1. cookie47121314
    cookie47121314 Member
    31
    6
    Mar 18, 2017
    Hey guys, I recently purchased a used raptor from a dealership. The owner before me put some amber leds on the running boards but only one out of 4 worked. I decided hey those look cool so I ordered some new ones. My issue with the install is I found how he had them wired(to the park lights I thought. So I decided to hook them right up like he did. Of course as this isn't my first rodeo I checked them and nothing happened. Now I'm at a loss. The lights work fine but I have no clue what he tapped them into. I did pull the mess apart he had and found what wire they were connected to but I'm unsure why they won't work. Please help!
  2. iumbastu
    iumbastu Member
    41
    9
    Nov 21, 2016
    Boston Area
    Shoot this one isn't easy just looking at a bundle of wires. Can you provide some more details? Is this the bundle on the passenger side fuse box etc? Have you tried the lights with the car on/off or key in accessory mode? I'm guessing he, prior owner, leveraged a wiring diagram but there's not enough info to respond (or at least for me to help you.)
    Try to add in additional details and let's see what the response is...
  3. TornadoRaptor
    TornadoRaptor FRF Addict
    2,255
    190
    Nov 9, 2016
    NY
    Welcome to frf and Raptor life. Congratulations on your new Raptor. Good luck with your lights.
  4. cookie47121314
    31
    6
    Mar 18, 2017
    Thank you for you input! And I'm a proud raptor owner so far haha thanks guys! But to try and get us a little closer it is actually pulled out of the loom on the drivers side right off the frame. The one light worked as the park/running lights were on. I did recreate this by turning them on even tried starting it still no power.
  5. The Car Stereo Company
    The Car Stereo Company aka nosbusa Supporting Vendor
    40
    24,779
    8,275
    Jul 8, 2012
    here, on frf
    go inside for the power connection. that connection there is old and becoming corroded. run your wires to the passenger side and tap power from the bcm/fuse box. that outside connection is going to give you problems in the future
  6. Black_Valkyrie
    Black_Valkyrie Full Access Member
    274
    59
    Jan 8, 2017
    You'll need some testing tools.
Share This Page
