GEN 2 18x9.5 +12
Discussion in 'Ford Raptor Exterior Forum [GEN 2]' started by Fshnrig, Apr 8, 2020.
  1. Fshnrig
    Fshnrig Full Access Member
    67
    64
    Jan 4, 2020
    Snohomish, WA
    Hey Guys,
    Need a little advice. Id really like to get 18s for my 2019. Ive seen that 9" wide wheels with a +12 offset works all day long, no issues. But I saw a post in a thread where someone stated that his tire shop wouldnt mount his 17x9.5 +12s because it was too close on the inside. Can anyone shed some light on this? Is that 1/4" more that significant? TIA.
  2. Raptor911
    Raptor911 FRF Addict
    4,071
    1,536
    Aug 9, 2012
    Ashburn, VA
    let's do the math.
    OEM wheel width is 8.5 at +34mm
    your wheels is 9.5" at +12mm
    34-12=22mm
    So your wheel is pushed out 22mm which is 0.866142 inches
    But because your wheel is one inch wider than OEM, you have to add .5" back into offset on the inner and outer of the wheel.
    adding .5 inches back to the inner part of the wheel is the same as adding 12.7mm.
    based on the math above, you should be fine as you moved out 22mm via offset but only 12.7 back due to a wider wheel. You should be fine.
    I hope the above makes sense
    Thebigblueraptor likes this.
  3. 911 Crazy
    911 Crazy FRF Supporting Member Supporting Member
    2,408
    1,001
    Jul 23, 2019
    Maine
    It was my understanding that there would be no math questions here. Especially story problems.
    isis likes this.
  4. Thebigblueraptor
    Thebigblueraptor Member
    6
    May 12, 2020
    Nyc
    I think I gotcha. I am in a similar boat, I am going for a 17x9.5 +6mm wheel on my stock tires and suspension. So my understanding is because of the wider wheel, it actually causes a higher offset? I just want to make sure im not rubbing at full lock.
  5. Raptor911
    4,071
    1,536
    Aug 9, 2012
    Ashburn, VA
    I think at +6 offset you should not rub.
  6. Thebigblueraptor
    6
    May 12, 2020
    Nyc
    Ok thanks! I was just hesitant full inch of width the wheel has with the +6. Appreciate it!
Share This Page
