GEN 1 14 Stock front springs have snapped, replace with OEM or upgrade?
Thekiwi
So both my front springs have somehow bit the dust, basically debating between replacing with OEM or going with the Eibach +3 springs. Truck currently has 60k miles on it, and suspension is completely stock at present. Will probably look at rebuilding shocks around 75k if that makes a difference.
It obviously lifts the front, but will there be an increase in the max height of the truck? There's a parking garage I have to fit into and only have a couple of inches to spare!
Any other pros or cons? Thanks.
B E N
Frederick, CO
That's got to be a metallurgical issue, something in the batch. I would love to see pics of the springs when you get them off.
If you have a couple inches to spare geisers would do it for you.
Dane
Littleton, CO
Couple things. Any time I break something I take it as an excuse/chance to upgrade. Go with the Eibachs.
Also, you are at 60k miles and due for a shock rebuild anyway. Save yourself some time and rebuild the shocks when you do the springs. You have to pull them anyway.
IamCanadian
Barrie, ON
I just install new OEM shocks rear and front c/w Geiser spring on the bottom perch on my 13. One word awesome.
IamCanadian
Barrie, ON
Gary, the answer to your question is, I found the ride better than my OEM on low and mid perch. The truck handles better at high speeds on and off road, especially in the corners. I have just ordered 37 KO2 boots and will be getting them installed on Friday, I cant wait to see how the ride is like and how it handles then. I never did like the E load KO2.
