'11 6.2 trouble codes P0023, P0024, P0456
mattt
Truck runs perfectly, has no driveability issues. However, in order to pass smog check here in CA, there must be no codes present and CEL must be off. These 3 codes have been an on again off again problem for many years, even though the truck runs perfect, and has no decrease in mileage.
Anyone know what sets these 3 codes and what the possible cause or repair to deal with them permanently is? Thank you in advance.
M
mattt
Awesome, thank you for the info. Which side is bank 2 if you know? I'm assuming the "vct22" solenoid is the cam sensor that is in the valve covers at the front? Thank you again.
EricM
OHIO
Bank 1 is the side of the engine with the #1 cylinder on that side. Bank 2 is the other side obviously. You'll just have to figure out which side the #1 cylinder is on a Ford 6.2L- I'm not sure about that.
BenBB
Lots of different places
I had P0456 on mine; it's either the capless fuel filler/fuel door or Canister Purge Valve (CPV). If you hear a ticking from the top LH engine area where the CPV lives, and/or have it take a long time to start right after filling the tank with fuel (cranks longer than usual or doesn't start the first try), replace the CPV.
M
mattt
So I had a hunch that I couldn't confirm with the limited code reader tool I have, so I dropped the truck at a local shop for diagnosis. In the past, when I wiggled the wire connector or unplugged it, I could get the code to go away and stay off for a while. That had me suspecting a connection problem. So today, according to the shop there is a problem with the connector or wire pig tail. Apparently a replacement connector is available from Ford for about $30. So either I'm replacing the connector or the shop is with their hour diagnosis.
