Craven Bullet Antenna Reception has decreased over time
SlimChaChi
NJ
seemed like after my fenders were installed there was slight static but nothing crazy and only with certain stations. i had maybe 1 or two light bars prior to the fenders, have since added a few more plus an additional relay setup, reception went straight to hell after that...ended up with sirius, don't see myself going back to regular radio any time soon.
Kellen@Craven
It's pretty odd to hear it degrade over time. An issue with length could be solved by removing the thread from the bullet. I would even send you a new one if you like.
Take the thread out and then put it into the truck first, then put the bullet onto the thread by hand, maybe that will help.
---------- Post added at 04:27 PM ---------- Previous post was at 04:25 PM ----------
My 50 cal. bullet antenna has been in my glove box ever since I installed my HID lights. I don't know if I messed up the wiring or something, but whenever the lights are on I have a ton of electrical interference. I've tried installing ferret magnets on all the wires near the lights and added additional grounds, to the frame. I plan to 're do all the ground wires directly to the battery. I'm running out of ideas.
I remember that. I was thinking, what about a rubber insulator to keep the Bullet from touching the body of the truck when it is screwed down?
NJStangersJonathan
NJStangersJonathan
North Jersey
Thank you, I appreciate that. By any chance do you know the exact size of the screw that is used? I was debating trying a longer one if not maybe an insulator.
Kellen@Craven
I can get a longer one for you, how long do you want to to be exactly? The stud should extend almost exactly the length of the stock Antenna already?
John Tanglewood
Stamford, CT
I only use Sirius in my truck, and I've never had any issues at all... even in overhead tree coverage or areas of cliff faces.
Sirus is usually different because it's connected via satellites. So reception is easy to grab.
FM quality overall is spotty with my .50cal, but I have not noticed a decrease over the 6mos I've had it and I use it daily. Also wasn't aware of the screw adjustments so thank you!
Marcsc1
Alden, NY
Put the 50 cal on the pay it forward thread? Lol
On a serious note, if not using interested in selling it?
