Aerial Video Drones by GLRE
Kanakry
Great Lakes Region
Have you wanted to get great action video but either didn't want to spend thousands of dollars or be forced to use a subpar camera?
Do you want to have the most badass Drone at an event or the Park?
Great Lakes Raptor Excursions is now offering Quad/Hex Copter builds. Aerial Video Drones by GLRE are not the DJI Phantoms you see flying all over the park. All AV Drones built by GLRE will be flight tested and will come with everything needed and labeled except LiPo batteries and Lipo Charger. Each build will be custom built and fully customizable to the customer’s needs.
Note these are not toys; the Quad/Hexcopter is capable of very high performance flight and lifting quite a bit of weight. (3-7 lbs in addition to the copter)
Flight time will vary based on batteries selected. Expect between 7-15mins depending on mAh size
Builds take 3-4 weeks depending on parts availability
Stage 2 flight footage showing shadow of drone
Stage 2 flight footage of Rausch Creek Offroad Park
Please see details below.
Stage 1: F450 Quad Copter
• F450 Quadcopter with four 1000kV motors and ESC’s
• KK2.1 board (autoleveling, beginner and advanced flight with a turn of a knob)
• 9 Channel TX and 8 channel RX
• Standard Go Pro Mount below the frame
• Fully setup for smooth and self level flight. Put battery in and fly.
• 2 full sets of props (White for training, Black for video and normal flight)
• $500 + shipping
Stage 2: Everything in Stage 1 plus
Retractable Landing gear video
• Multifunction anti-vibration landing skid with Go-Pro mount
• Retractable Landing gear
• $700 + Shipping
Stage 3: Everything in Stage 1 & 2 plus
• F550 Hexcopter instead of a quad
• Excellent flight performance and capable of lifting a Multiple Go-Pros or a Camera * with addition of gimbal
• Includes DJI Naza Lite
• $1200 + shipping
Stage Ultimate
• Carbon fiber frame and Props
• Sleek and professional design
• Stealth Edition: Black everything except red parts to designate front
• DJI Naza Lite Flight Contoller (GPS Lock, Return to Home, Altitude hold)
• DJI Naza V2 Flight Contoller +$160
• DJI Data link +$200
• Heavy lift motors and ESC's
• Capable of lifting over 10lbs
• Retractable Landing Gear
• Powered Camera Gimballs 2 axis gimbal
• Folding arms for easy storage and transportation
• KC Lighting for night use
• 9Ch Transmitter and Receiver
• Voltage display
• Mini-piezo voltage alarm
• $2200 + shipping
Add on’s
• Cyclone Edition: KC Cyclones under each engine in choice of colors +$240
• Stealth Edition: Black everything except the localizer ball +50
• DJI Naza Lite Flight Contoller (GPS Lock, Return to Home, Altitude hold) +$160
• DJI Naza V2 (GPS Lock, Return to Home, Altitude hold, Ipad Control(Requires Data link)) +$300
• DJI Data Link *Requires Naza V2(Flight Planning, Autonomus operation, Ipad control) +$200
• Heavy lift build (Motors, ESC's, Naza, Aluminum arms) +$
• F450 travel case +$100
• Pelican Cases- $200-250
• TBS Discovery Frame instead of F450 +$125
• Aluminium arm upgrade +$100
• Tall Landing Gear +$30
• First Person Video setups as well.
• Powered Camera Gimballs –Contact for specific cost
• LED’s - Contact for specific cost
• Any additional idea’s please contact
For more information or to order please contact.
[email protected]
mkelly984
Good idea, those flame wheel's are some amazing machines. I use a Trex 700 myself just because it flys a little faster.
Kanakry
Kanakry
Great Lakes Region
The Flamewheels are great fly really easy and stable and there is quite the aftermarket for them.
Aluminum arms, Mounts for Larger engines, or counter rotating setups, etc.
t_j
Chicago, IL
Next step, auto take-off & return from a charging dock mounted on the roof or in the bed along with a button on the dash to make it take off and record some footage then return on a second press.
Kanakry
Kanakry
Great Lakes Region
I can do the return to take off but someone has to control the take off as of now.
With enough programming I can make it follow a source unit. ie your phone. The programming is the intensive part.
---------- Post added at 01:34 PM ---------- Previous post was at 01:33 PM ----------
This is interesting. I was thinking of picking up a quad for Havoc II. I didn't know there were so many interested people here.
Let me know, If we can finalize it/order soon I can have it build and delivered to you at Havoc saving on shipping.
