Has anyone run the Baja Designs Arc Bar?
SilentShooter
Siesta Key, FL
Just ordered a 30" Baja Designs arc bar for a custom SVC bumper they are doing for me. Was looking to see who has experience with them. Looks like the Baja bars have a High/Low and flash sequence you can toggle. When wiring them for the raptor is it a PIA to wire this functionality?
So the bumper will have four KC 6" Pro Sport HID's (2 Spot, 2 Spread) on the top and then the 30" Baja Arc in the center and an led cube in a fog pattern in each corner triangle.
Baja Designs
The wiring is quite simple, you just have run a ground from the switch and the other leg from the momentary switch to either a chassis ground our battery ground. Shoot our tech support department a call and they can walk you through it. Let me know if you need anything else, thanks - Christian
:everything:
S
SilentShooter
Siesta Key, FL
:everything:
Do you guys have cube lights with a pattern that will work well for fog light duty?
