NEW: Camburg Raptor MIG Shackles
Sales_@_Camburg
Huntington Beach, CA
Our Camburg MIG shackles replace the stock light-duty version your Ford Raptor is equipped with from the factory. The stock shackles are stamped out of thin metal and use a rubber bushing which both allow for a flexy component that also binds as it cycles since the rubber bushings are vulcanized into the shackle.
Our shackles are a fabricated boxed gusseted design that is much stronger and use polyurethane bushings that pivot smoother with less flex. They are MIG welded and powder-coated in our matte black finish and ready to be bolted on using the factory hardware. They are stock length, so they do not raise or lower the ride height and are a perfect match for Deaver leaf springs.
We will also have a TIG welded 4130 chromoly version available shortly.
ntm
Alberta, Canada
I'd buy a longer than stock set, for sure.
1/2" to 1" longer would work nice with my +3 nationals.
