NEW Light Option, you Guys need to check this option out!
lexmotorsports goodguy
The guys from GT Lighting just stopped by our shop to show us the new MK series. Which are available in 3w and 5w double row, and 10w single row,You guys need to check these out lights out, They are by far the best quality of LED lightbar, for a inexpensive alternative.
These also offer mounting options on the side [trunion] or bottom.
They have given me some room on the products to be able to offer you guys a discount, [as always]
All our MK series info list below
*New Design Miltary standard breather**To prevent condensation**
*High power Cree 3w LED/5w LED/10w/LED
*New Design 4 Layer LED PCB
*Integrated electronic thermal management
*Efficient heat dissipation
*100% IP 68 weather/water proof Rating
*Unique Durable multi layer Mar/UV resistant painting/coating technology
*Sealed waterproof connector,Heavy duty power wiring cable
*Vibration resistance of 304 grade stainless steel bottom bracket or side bracket available
*Operation Temp : -40 -- + 85 c.
*Running on any voltage including miltary standard voltage From 6v-60vDC, 9-48vDc or 9-32vDC
*Pass tests for Temperature Low to High ,Shock,UV,Humidity,Salt fog,Sand and dust,Water,Vibration ,Altitude.
*Beam pattern:Wide flood.Euro,Spot or Custom mix-patterm beam available
*CE & ROHS certification.
*2 years limited warranty
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
MagicMtnDan
Magic Mountain
The guys from GT Lighting just stopped by our shop to show us the new MK series. Which are available in 3w and 5w double row, and 10w single row,You guys need to check these out lights out, They are by far the best quality of LED lightbar, for a inexpensive alternative. {not China made}
Just curious, how do you know they're not "China made?"
Where do they make their LEDs? (You do know CREE makes their LED engines in China, right?)
How are they the "best quality of LED lightbar?"
I'll guess that GT Lighting USA may be operated by Americans but I suspect it's not owned by Americans (just a feeling I have).
One other question: After what RPG went through with Ford how do you guys get away with using "RaptorSVTParts.com" as your website and name? (Maybe Ford's lawyers/legal department hasn't found you yet?)
We are just trying to help the guys find products, alternatives to the higher priced lighting.
Although we do still offer VisionX, Rigid, Baja Designs as our main lighting lines.
The lights are made in Taiwan. How do I know, I asked! Yes I know CREE LEDS are made in China. So with that said I guess all light bars that have CREE LED's have a little Chinese in them. I'm sure you know about the different grades of Cree LED's as well ?
"best Lightbar for the highend/cost alternative" is my opinion, Holding them in my hand, and comparing them side to side to a china alternative there is a quality difference. Both are bright there is no doubt. But the GT design just seems to have a better overall fit and finish to the product. I also like the look better. As well as the mounting options.
Any colored lenses or covers? They look good
sorry there are not light covers being offered at this time.
---------- Post added at 02:59 PM ---------- Previous post was at 02:59 PM ----------
Where can we find pricing?
pm me what you are looking for
justvettn
GTA
Thats actually kinda sad to promote them as (not china made) right away I assumed made in America, only to find out its made in Taiwan?
Really, let me change my original post it seems to be a problem for more than one of you guys. sorry to offend.
***edited op***
Cruisin67
Raleigh, NC
^Correct. My best friend works at that facility in the accounting department, so I can speak to the accuracy of that.
