Torque specs
JSIN138
All credit for this goes to pirate air. Thanks for this info, You Da Man!
I just took the numbers from the OP & put them into a 1 page reference sheet. After I did this, I figured the right thing to do is share it with anyone interested.
Inside the attached file TorqueSpecs.zip is the PDF
**Disclaimer** - refer to post #1, same applies here.
--Cheers
  • TorqueSpecs.zip
ABNRAPTOR
Hey Pirate air, I'm going to google these so I'll have 'em for tomorrow, but here is a list of things I want or need to get a good torque on after a exhaust system swap. Might be good stuff to add to your list.
Manifold/Header bolts
motor mounts
transmission mounts/ crossmember support.
pirate air
pirate air
will plunder your booty
motor mounts
Sorry, just saw this. If you still can't find them shoot me a pm and I'll see what I can dig up.
--Cheers
That's freakin awesome! Nice job
NickPic83
Rockland County NY
motor mounts
I am also looking for these specs. Anyone know?
Sent from my DROID RAZR using Tapatalk 2
BIRDMAN
Birdministrator
Boston
I'd say 50 on the headers and 100 on the motor/tranny mounts and cross member? if that seems too tight then just use the good n tight method and recheck after a couple days.
Hockster
My 45ft Bluewater Party
Winchester, Va
There are many torque application charts available online. Each fastener has a set range that should torqued to.
All set with Proof load, applied torque yield strength accounted for. IF you want the correct torque for a different grade or a diff material type just call one of the fastener companies and ask what torque you should use. I guarantee that SW will have a torque chart available for you.
