New (m&r releases the 60 led behind the grill kit)
WHYUMAD
New Orleans, LA
Would y'alls 24" be able to fit in the lower grill? I have a rigid 20" & it has some play on both sides. If y'all can come out with a lower grill kit, I'd be very interested in doing a 24" in the lower grill, the fog light kit, this 30" kit for the top of the upper grill, & a 30" kit for underneath the FORD on the top grill. Let me know if y'all can see about making something work, because I'm about to pull the trigger on the dually d2 fog light kit in the next month or two if y'all don't have a lower grill kit that can replace my Rigid 20". Thanks, & it looks great btw.
NY SCREW
new york
nice can it be mounted on just the top or can it be mounted below the word ford as well?
MandR Automotive
MandR Automotive
This particular kit is only for the above the Ford sign just based on space. We are going to come out with the brackets for the below the Ford sign for the 44" bar
HSDMORGAN
Torrance, Ca
Looks like the cord is just hanging down when the hood is open. Was it secured better & how much does the grill block the light out? Looks good though.
MandR Automotive
MandR Automotive
you need to route the cable how you want. just use zip ties and tie it to the factory wire harness thats there
Yup that picture was just to show how it looks mounted from bottom of the hood. You can route the cable any way that pleases you
