Memorial Day Sale Starts NOW... Plus.. New Items!!
Specialtyperformanceparts
Memorial Day Sale Starts NOW....
Just visit SPVparts.com
Also, we have some new harnesses and adapters we are loading up!
These new harnesses and adapters are just want you have all been asking for! More solutions!! More Options... These are ALL In stock and in hand. We are loading them up now.
1: New Heavy Duty Light Bar Harness with Built in Relay - Adaptable for your BIG lights and Light Bars! Still Plug N Play for your switch wires, still adaptable to any make light or brand! With or Without backlighting.
2: New Raptor OEM Harness Splitters... Many of you have asked to combine either your OEM Rigid lights together onto the Fog switch and free up the Aux 1. We produced a Molex 2 wire Splitter to allow you to easily combine the 2 OEM Rigid Lights to your Fog or Aux 1 connection.
Video- (New Splitter not shown, but these adapters are an example. They are just a split into 2 connections)
3: We already released our numbered switch wire connector extensions. These allowed you to have #1-#6 labeled on your Aux wires as well as add 8" in length to the existing short wires. Now we have released a second option with Pass throughs as well. There are 6 male and 6 female pass through connections. This allows you to install connectors on both ends of your pass throughs that are labeled P1-P6 on both ends for easy identification and connection as well. These work great for both the Raptor F-150 and Broncos or Super Duties.
Video-
4: Our new Crossover Adapters. These are REALLY cool. With these you can take our harnesses to the next level. Even more plug n play customization. We have our single DT or Weather Pack crossover adapters as well as our DT or Weather Pack SPLITTER crossover adapters.
With these new adapters. If you have any 2 wire lights, such as Baja Designs, or Rigid D-Series. You can utilize our 3rd wire which is normally for backlighting, in applications for a second switch control. So for example. You can have ONE A-Pillar harness with 2 Baja Lights. Plug in our Crossover Splitter adapter and connect to both. Then you can connect ONE pair with the red wire to one switch, and the other with the white wire to another switch.
Or, for those with the Baja Squadron behind the grille kits. We have had many ask us for separate connections to make one pair Amber and the other 2 pairs clear. Normally you would need 2 different harnesses. Not with this set up. On our 6 chain harness, you can simply plug in the crossover adapters to any 2 connectors you want to be on the secondary (white) wire. Then the rest into the normal red wire and control them independently.
Video-
We also have our Bronco Prep Fog connector adapters. For those who have a Bronco as well. With these, if you have a capable bumper without fogs, you can connect 3 different types to the prep wires. A DT 2 way. A Weather Pack 2 way. Or a Weather Pack 3 way with a backlight port to pull power for backlights as well.
You can check out these videos on these new adapters and harnesses ABOVE and check out SPVparts.com for the sale!
Feel free to reach out for help and questions!!
[email protected]
317/934/6778
Here are the new Switch Wire/Pass through Extension kits-
And the 6 numbered extension wire kit (These are the same and included above with the other pass through versions as well.
Nex
RIP CoronaRaptor
Washington State
We may? Do you have pics or a part number of that specific bumper and I can cross reference.
It's a version on this bumper. Has the rear park sensors in it. Not listed on their website yet.
I would think something like this tube mount would be best. This is a link to Baja, but we can get them too. Of course we already have all the lights and harnesses in hand and can ship everything to you.
There are 3 sizes. So it would be good to know the diameter of the tube in the ends of the bumper.
John
Nex
RIP CoronaRaptor
Washington State
John
Thanks John. I will measure the bumper and call you next week to order it.
Edit:
Cross bar has an outside diameter of 1.25" so might need a filler or grind down the 1.5" bracket.
