Raptor R Eibach Spring kits
Stormtrooper
Raptor R
Huntington Beach, CA
To any Raptor R owners that are interested in installing a Eibach spring lift on their new Raptor R, my R is scheduled to be dropped off at Eibach on the 20th of this month for R&D to develop a Raptor R specific spring kit.
According to Eibach after they fit the truck it will take approximately 3-4 months to get their first shipment in for retail sales.
I’ll keep you all posted on this thread with the progress and estimated availability date they will be come available.
Stormtrooper
Stormtrooper
Raptor R
is the purpose to level the front end of the truck only? Rather than using a perch kit.
The kit will raise the rear end, and front end to level out the truck for a better stance and will potentially provide a little more ground clearance as well.
Correct, Eibach Pro-Lift-Kit springs are designed to provide a suspension lift for your vehicle without the use of coilover systems or spacer lifts. Eibach spring lifts allow full range of suspension travel without additional stress on bushings and ball-joints as seen with spacer lift systems.
I will keep everyone posted on the heights once the truck is fitted at Eibach. Should know more by end of day Friday the 24th when I pick up the truck after their fitment tests have been completed for the prototype to be made.
Stormtrooper
Stormtrooper
Raptor R
Eibach completed their first round of testing on the Raptor R!
So stoked to be apart of their Raptor R development project!
Im loving her new stance with their front lift springs and heavy duty rear spring kit! What do you think..?
Check out their Instagram post and stay tuned for their upcoming Raptor R kits!
cashed
Do they seem a bit high? Will they compensate for bigger tires? I have always appreciated the low stance of the Raptor, and the ability to run 35s+. No judgment, but the 37s look tiny now.
Please let us know your feed back because I have been debating about running the new Eibach Coils.
wweaver
East TN
Not sure they would need to change a thing from the regular Gen3 37 springs and what is needed for the R. Weight difference is negligible, probably less than weight of which fatazz ( me included ) is driving the truck and how much gas is in it. I was assuming I could use the regular 21-23 springs whenever in the next two years I get my truck.
