Heated Wheel Retrofit
xlover
Boston
Those who are ordering from various ford parts sites… are you leaving your order open if told the part is on back order?
I got the hvac panel with temp dials from eBay but not thrilled with it, has some minor blemishes but would prefer brand new on a brand new truck
ricsan
Houston
It would be really nice if Ford installed the heated steering wheels and just left out the SCCM/Clockspring as then its really only about $500 to retrofit which isn't that bad overall.
I have a 2023 whiteout heated steering wheel but my steering wheel does have the wiring for the heated option, I guess I ”only” need the SCCM/clockspring and the HVAC dash
Chop96
Fredericksburg, VA
When I ordered the HVAC panel from Ford Fairway Parts it went on backorder for about a week or so, then shipped right out. Total time for me was about two weeks from order to receipt. Ordered about three weeks ago.
:cheers:
xlover
Boston
:cheers:
then I probably shouldn’t have canceled my order when I saw back order I thought it would be never….
pnwobrigade
WA
Digging into this little more for 23 Heated Wheel Retrofit, so if we want to have a heated wheel and digital knobs these are the associated PN#:
ML3Z-3F791-BB (Clockspring)
ML3Z-14A664-B (SCCM)
ML3Z-19980-K (Digital Knobs)
From what I can tell that's about $400 in parts to retrofit, am I missing anything else and are those the correct PN# per earlier posts?
xlover
Boston
As I understand it ML3Z-3F791-BB is an assembly, clock spring + sccm
MZRaptor
FYI may still need the whole SCCM, as some of them are missing pins, even if you replace the clock spring.
Also, may need a wheel. Need to check if you have the heating element.
Couple of other small parts needed as well.
The problem may be finding the parts due to national backorder.
